DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Worcester Heatslave 20/25 Oil combi boiler
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
tombox68
from United Kingdom
PostPosted: Sun Apr 12, 2009 5:02 pm Reply with quote
Can someone please help. I have a Worcester Heatslave 20/25 Oil combi boiler. When I select the DHW only, the central heating comes on as well!! . i think it could be the diverter vaule that is at fault .could anyone confrim for me plus were would the best place to get a honeywell diverter vaule vc4613-30 from
cheers
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3521 times
PostPosted: Sun Apr 12, 2009 5:04 pm Reply with quote
That sounds likely.
Its possible/probably that the diverter valve is specially configured for your boiler.
In that case Parts Center would be a good supplier to try first.
It may have just jammed and you could try to check that first.
Tony
Back to top
 Alert Moderators
tombox68
from United Kingdom
PostPosted: Sun Apr 12, 2009 5:32 pm Reply with quote
thank you for your reply would i have to change electric valve or just the body??the electric valve seems to work ok as you can see the plugger going up and down .how would i test if it is jammed ??
cheers
Back to top
 Alert Moderators
wilhelm
from United Kingdom
Thanked: 1 time
PostPosted: Sun Apr 12, 2009 7:06 pm Reply with quote
change the whole assy.
as tony says, valve is special to your boiler. got a socket on the wires etc, to plug onto pcb .
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3521 times
PostPosted: Sun Apr 12, 2009 7:20 pm Reply with quote
I think that there may be a repair kit with a capsule to replace the moving parts inside the body. Others can confirm.
Even if there is then it is often not such an easy DIY job to replace it as it requires cleaning and lubricating.
Tony
Back to top
 Alert Moderators
oilman
from United Kingdom
Thanked: 26 times
PostPosted: Sun Apr 12, 2009 7:25 pm Reply with quote
And no professional would do it for the same reason AND because of the continuing liability for the repair.
Back to top
 Alert Moderators
tombox68
from United Kingdom
PostPosted: Sun Apr 12, 2009 7:42 pm Reply with quote
thank you all for your replys .would anyone no were i could get a parts list for one of these boilers
cheers
Back to top
 Alert Moderators
tombox68
from United Kingdom
PostPosted: Tue Apr 14, 2009 6:11 pm Reply with quote
well went to plumbing centre today and i didn't need to get full valve just a cartridge took 20 mins to fix and 34.00 not bad
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Worcester 26/32 Heatslave Oil Combi Boiler 3 340 Wed Sep 16, 2009 11:38 am
Bosch/Worcester Heatslave 15/19 combi boiler. 2 4340 Mon Mar 01, 2004 6:50 pm
Worcester Heatslave Highflow floor standing combi boiler 2 2800 Mon Apr 21, 2008 9:45 am
Worcester Heatslave 2+ combi boiler (installed early 80s) 7 580 Wed Oct 21, 2009 7:38 pm
Worcester combi boiler heatslave 18/25 4 40 Wed Aug 29, 2012 8:38 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
