Joined: 05 Dec 2004 Posts: 7 Location: United Kingdom Thanked: 0 times
Posted: Sun Dec 05, 2004 10:48 am Post Subject:
Radiator Valve Dual Flow Thermostatic 15mm
I am replacing a couple of radiators in my house, but have ben recently told that fitting Thermostatic Radiator Valves may cause problems!? Does anyone know why this might be? The heating is run from a combi boiler.
Joined: 18 May 2004 Posts: 19153 Location: Tennessee, United States of America Thanked: 400 times
Posted: Sun Dec 05, 2004 11:01 am Post Subject:
as long as the system is clean and you fit them the right way round or get bi directional shouldnt be any probs
dont fit one in the room where the stat is tho
if one of your rads has two l/s valves dont fit one to this either
Joined: 24 Jul 2003 Posts: 18664 Location: London, United Kingdom Thanked: 62 times
Posted: Sun Dec 05, 2004 12:46 pm Post Subject:
If you replave rads you usually have to go a bit shorter, and mount the rad so it lines up withe valves, then use short extensions. If you turn the valves off, take the bits out of the old rad and use them again, you only have to.drain the one rad.
Posted: Sun Dec 05, 2004 6:55 pm Post Subject:
Thanks for your help so far.
I had already removed one rad to do some decorating... Just put it back for the moment before I change for a new one.
The problem I now have, is that the top half is cold. I tried bleeding it but that did not seem to solve it. Neither air nor water came out. Any ideas?
Posted: Sun Dec 05, 2004 9:33 pm Post Subject:
My boiler has no water in it, it is quite litterally boiling!
It is a Worcester 24cdi rsf which requires a plastic key to fill. However the key has gone missing! Is there another way by which I can fill it, as I currently have not hot water!?
Joined: 08 Feb 2004 Posts: 6462 Location: Wolverhampton, United Kingdom Thanked: 5 times
Posted: Sun Dec 05, 2004 9:51 pm Post Subject:
Sorry mate.
The Worcester has a plastic key which you need to insert to allow you to refill via the round valve.
Can you not borrow one from someone until you get chance to buy
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
