DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Zanussi electrolux making noise when spinning
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
shedi123
from United Kingdom
Thanked: 1 time
PostPosted: Sat Apr 18, 2009 8:55 pm Reply with quote
I have a Zanussi electrolux washing machine thats about 3 years old. Its started making a grainy noise when spinning ( noisier the bigger the load). Is this the bearings going? It doesn't make this noise when its washing. Is this repairable? Any advise would be great. Thanks
Back to top
 Alert Moderators
cakeman
from United Kingdom
Thanked: 49 times
PostPosted: Sat Apr 18, 2009 9:51 pm Reply with quote
from your description it would seem your diagnosis is spot on
change the bearings now with a new seal, then you be back on track
but 1st just check the belt isn't rubbing or something amiss there
Back to top
 Alert Moderators
shedi123
from United Kingdom
Thanked: 1 time
PostPosted: Sat Apr 18, 2009 10:01 pm Reply with quote
That was a spot of luck. I'll check the belt!! If thats ok are the bearings cheap and simple job to do my self. I'm a spark anyway so i got some kinda skill icon_lol.gif
Thanks forthe advise cakeman
Back to top
 Alert Moderators
cakeman
from United Kingdom
Thanked: 49 times
PostPosted: Sat Apr 18, 2009 10:29 pm Reply with quote
buy a bearings & seal kit - under £25 easily
liberal amount of sealant on drum seal when fiting
check the spider isn't skuffed - if you earlier as you described you'll be ok there icon_cool.gif
take photos of everything before you touch or remove - can take time but 10% of the time if you get it wrong icon_wink.gif
if you a sparky then i not in your league - mornings work for you i'd guess icon_razz.gif
cling film new seal & bearings individually & tightly
then when you fit them on heat the spider , drive them on with the old bearings as the shield and they'll tap on easy
good luck
Back to top
 Alert Moderators
shedi123
from United Kingdom
Thanked: 1 time
PostPosted: Sat Apr 18, 2009 11:00 pm Reply with quote
I may be a spark but that all sounds very confusing. Whats the spider? I'll take it apart tomorrow i think and sus it out.
Back to top
 Alert Moderators
cakeman
from United Kingdom
Thanked: 49 times
PostPosted: Sat Apr 18, 2009 11:14 pm Reply with quote
found this on tinternet which has a picture
http://www.espares.co.uk/part/washing-machines/zanussi/wjs1397w/p/1085/332/0/1005379/103724/drum-spider.html
by the time you finish tomorrow you'll be an expert
Back to top
 Alert Moderators
jj4091
from United Kingdom
Thanked: 132 times
PostPosted: Sun Apr 19, 2009 6:25 am Reply with quote
The spider is not available by itself fot some Zanussi models & you have to buy the complete inner drum assy. which makes it an uneconomical repair. Ensure you can get the spider before you waste your time stripping the machine.
Back to top
 Alert Moderators
Leccy758
from United Kingdom
Thanked: 193 times
PostPosted: Sun Apr 19, 2009 10:50 pm Reply with quote
Before condeming a machine with a rumble as being drum bearings (most likely though) take the belt off and try rotating the drum seperately and the motor as well (bearings can go in either)
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Indesit WIDL126S making such an explosive noise on spinning 8 1000 Thu Jun 04, 2009 2:32 pm
damsel in distress!!indesit machine making Vloud noise 6 260 Sun Oct 24, 2010 5:17 pm
Bosch Fridge Freezer - Making a terrible noise! 8 120 Sat Sep 24, 2011 10:25 pm
indesit cooker door making an awful buzzing noise 3 60 Tue Dec 20, 2011 10:03 pm
beko TZDA524FS making a very loud noise 3 40 Fri Nov 02, 2012 1:20 am
DIYnot
