help with roof
18 Feb 2006
Birmingham
Hi all
Just getting info so I plan the roof build on my shed.
wall to wall it is 4.85m x 5.7m, being built in 6" blocks
What i need to know, is ridge, rafter and wall plate sizes. Ive seen 6x2 in our local yard for £6 for 3.6m lengths. 8x2 4.8m length for £11.
I want the ridge beam going along the short length, so the rafters have a shorten span.
is 6x 2 fine for the rafters, and can this be used for the ridge?
What size should wall plate be?
Do i need restraint straps?
4"x 2" would be ok for the wall plate though i prefer 4" x 3" (tanalised).
Holding down straps will be useful every 2m, restraint straps will be needed on a masonry gable end.
What pitch do you intend setting the roof?
You want the ridge beam across the longest run to give the shortest rafter length.:confused:
I.e. 4850 divided by 2 gives a 2425 run. At say 25 degrees this will equate to a 2668mm long rafter. A 6"x2" will eat it.
You will also need joists or collars to stabilize the roof. 4.8m is a fair span.
What ever you use for the rafters the ridge beam needs to be deeper, but not necessarily the same thickness. This is so the whole ridge-plumb cut is seated on the ridge beam.
I have concrete tiles, so thought of 25deg
I I put the ridge along the longest part, the roof doesnt look nice, plus I would need a 6m ridge beam.
I thought 8x2 for the ridge beam, 6x2 for the rafters.
As its only a shed, collars rather then joists.
Do I face-nail rafters to ridge beam?
Also do I have to birdsmouth the rafter or can I use truss clips?
Anything from 25-45 degrees is within the realms of conc' tiles though 25 degrees is more sheddish.
A ridge beam can be joined.
Sounds good.
Cool.
Face nail, eh? You just bank a spike through the top and skew one each side.
Truss clips are only suitable for trusses, yes you need to b/m over the wall plate.
All sounds good
Just need to look into how to birdsmouth correctly and how to cut rafter overhang correctly so to put facia board
