I've attached an image to this post to help illustrate what I'm saying as, no doubt, I'll talk myself in circles here.
We have a waste pipe (sink, dishwasher, w/machine), which runs along the back of our house to the pre-existing drain. The pipe was covered in concrete with a channel for surface water scored into it. The yard slopes towards the house.
The concrete is flush against the wall but there are some holes in it, so the surface water drains down these (not intentional). When the rain is very bad it also runs into the air brick as that's only just above floor level. In fact, hardly any of the water goes down the drain.
I've been researching my options and would like some advice on what's best to do.
As far as I can tell I'm not actually allowed to put a linear channel in as this would have surface water running in to the dirty water drain? Is this right?
If so, can I dig a trench, treat the wall below and fill it with gravel? If so what depth should I go to? Should I put a membrane in to protect the wall.
Or, should I put some sort of pre-fromed concrete channel in to simply protect the wall? Is there any point to this as the water would just sit in the channel?
Any advice and or better solutions most welcome.
Thanks in advance
Thanks in advance
