Crack in wall and rainwater leak
28 Jun 2004
I've got an external wall following on from the boundary wall. When the (brick) wall and (block) extension was built about 4 years ago the builder put in a DPM in the extension wall at the same level as the boundary wall, but left a bit sticking out and cement/sand plastered over it. Now there is a crack along (about 4 metres long) where the DPM sticks out on the extension. Water has seeped in through the crack and what looks like salty deposits has appeared on the internal plaster.
Whats the best way to fix the problem on the outside and inside of the extension wall?
You need to trim the DPC off, and point the joint. Then make sure that the render has a proper bellcast which does not cross the DPC, but is angled sufficiently to cast water away from it.
I was going to do something like.
Outside wall:
Take off render
Cut back the DPC
Apply salt neutraliser
Re-render with sand/cement
Inside wall:
Take off plaster
Replaster
Does that sound ok?
The drip detail at the DPC is the most important.
Applying salt nuetraliser externally will do nothing, and hacking off good render is a waste of time unless it needs to be removed
OK for the outside render. What about the internal plaster, its bubbling and I can see white (salty) deposits. I was going to use the neutraliser to get rid of the salt and then replaster, what should I do instead?
