Remove a radiator
22 Apr 2009
Hi, I am trying to remove a radiator that has 2 pipes going in at the same end as apposed to most that have a pipe at each end. I am currently having a new bathroom put in and the plummer that I am using doesnt know how to remove this radiator. I have contacted several plummers but none of them can remove it. Any ideas ?
if it is a pressurised heating system then drain it, if u have a f and e cistern in the loft then plug the feed and vent and this will stop the water in the pipes coming out, works the same principle as aucking water into a straw then puttung your thimb over the end, the water stays in the straw , u want to find a decent plumber m8
...I am currently having a new bathroom put in and the plummer that I am using doesnt know how to remove this radiator. Any ideas ?
I have the idea the plumber speaks polish.
Plumbers that don't know how to remove a rad do not exist, therefore you have not spoken to a plumber but to cowboys.
