Alarm will no longer activate
22 Apr 2009
Lancashire
I have an old A1 PR5008 alarm system which was in the house when I moved in. The previous owner did not have the manual and it appears that the company went bust a few years ago!
Anyway, the alarm would keep going off even though not activated (quite annoying at 6:30am on a Sunday!) so disconnected while I sourced replacement batteries.
I replaced the backup battery, the door alert and PIR batteries but now cannot activate the alarm!
When I put in the code nothing happens but if I press reset/cancel, the alarm goes off! I then put in code to deactivate which works to turn it off!
Has the panel died? Will a new wired panel work with the existing wireless PIRs or does the whole lot need replacing?
Many thanks in advance for your help,
Warren
did you ever discover the root cause of the problem? I have the same issue with mine and have no manual
