home made slabs
11 Dec 2006
Leicester
good morning all
hope someone can help, im making my own mold for some slabs i want but im thinking that the concrete will stick to the wood, i need to make 10 slabs in total but only want to make 2 molds, time is not a worry so im happy to wait for them to set, so my question is will it destroy the mold each time i make some or can i put some sort of tough plastic in there to stop it from breaking each mold?
thanks in advance for the help
coat the moulds in cooking oil, that will help the concrete stop sticking to the wood. another useful tip is to hold a sander against the mould when you put the concrete in to vibrate the air bubbles out
i did actually think about good old pva coating but if your saying cooking oil mr T i could go for that cheers fella
I wonder if concrete formwork oil would be cheaper than using cooking oil (unless you have a quantity of used cooking oil you want to get rid of).
As Thermo says, vibrating the concrete when you pour it is essential; if you don't, the slab will fall apart when you move it.
How about lining the tray with plastic cling wrap?
Make the moulds with pegged (dowelled) not screwed joints so that you can knock the sides off to get the slabs out.
thanks for all the replies
if i use the plastic will it stick to the concrete?
Depends on how good a finish you get on the upperside of your mould. Experience will tell!
