drayton tempus three
26 Apr 2009
Oxfordshire
Hi, my Tempus three control box keeps clicking on and off inside box, i think it wants replacing. Could someone please advice me what to replace the Tempus three box with as it seems to be discontinued, best regards David
If your existing timer is using the standard 9-pin backplate, you can use almost any timer you like. Drayton Lifestyle and Tempus models use the same wiring, so that makes it easier, but other makes will work - you just have to swap a few leads round on the backplate.
If you have a mechanical thermostat it might be worth upgrading to a programmable thermostat.
