Removing a Raised Terrace
27 Apr 2009
Yorkshire
I have a small back garden spread across three levels. The upper layer has a patio, conservatory and access to the front.
The two lower levels consist of equal sized gravelled areas with slightly raised feature areas. There is a drop of approximately 40cm between these two areas.
I would like to raise the level of the lower area to create a more child friendly garden
Can anyone advise me on the best material to use to raise the lower level? Also, how much topsoil will I need to put down once the garden is level in order to support the turf?
