Overflow from boiler header tank running
7 Dec 2004
Hi there,
I've just moved into a new flat and found that the overflow from the boiler header tank runs. A plumber said that there is either a faulty washer or a problem with the ball valve and advised to turn off the tap that allows this flow to occur (temporarily).
How urgently does this need to be remedied? Access to the header tank is restricted incredibly and I don't know how a plumber is going to replace these parts.
In the meantime, what will happen if the valve/tap is switched off for a while?
Thanks,
Safe.
thanks kevplumb :D
I am still slightly confused, though: wouldn't having the
tap on, rather than off, make the tank run dry?
When it is on, in fact, the overflow leaks, so i could see that it could run dry.
Sorry for being a bit slow.
if the tap is on the water is getting in to the tank hence the overflow
if the tap is turned off it will stop the overflow
the water may evaporate if the heating is on
hence top it up occasionaly :)
