DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
thermostat for radiant rsf 24
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
drbenway
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 28, 2009 10:20 am    Post Subject:
Reply with quote Thanks
I have done a search here for info, but could not find much on this boiler. However thanks to useful tips here, I now have the full installation manual.
The boiler has an inbuilt 24hr timer [old school analog with the push/pull tabs] I would like to add a room thermostat, but to also keep it old school, pref a rotary type [maybe in F ?] , so its easier for my mum. although a basic digital would prob also be fine.
I also see from the Radiant manual that it is only a 2 wire connection to an external thermostat. [term 3 on pcb, out to therm, therm in to term 2 on pcb]
Can someone please recommend something suitable?
any help/advice much appreciated, thanks!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Tue Apr 28, 2009 10:25 am    Post Subject:
If you don't want to have to bother about running the wires to the new stat, have a look at the Honeywell analogue r/f stat.
A quick and easy job to fit where you like.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
drbenway
from United Kingdom
Thanked: 0 times
PostPosted: Wed Apr 29, 2009 7:02 am    Post Subject:
thanks for the reply
the thermostat location is very close to the boiler so wont need wireless.
on reading, Honeywell seems to be the preferred make here, so will something like this do?
http://www.screwfix.com/prods/26159/Plumbing/Central-Heating-Controls/Honeywell-T6360B-Room-Thermostat
http://www.screwfix.com/prods/40819/Plumbing/Central-Heating-Controls/Honeywell-DT200-Room-Thermostat
thanks again
Back to top
 Alert Moderators
drbenway
from United Kingdom
Thanked: 0 times
PostPosted: Thu Apr 30, 2009 1:07 pm    Post Subject:
well in case anyone else searches here for a thermostat for the radiant rsf24 rsf 24
the honeywell dt200 works well.
connections for a unit with an existing internal anolog clock are
move yellow out from Clock, from TA/Term 2 to OR / term 3, on PCB
add wire from OR/ term 3 on PCB, out to A on Honeywell
return wire from B on Honeywell to TA/ term 2 on PCB
hope that helps
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Radiant 2 260 Mon Dec 11, 2006 7:20 pm
Guidance re Gas Fires (Radiant/Confector) 3 400 Sun Jan 07, 2007 4:33 pm
pressure rising on radiant rsf24 3 680 Sun Mar 25, 2007 4:21 pm
Radiant Fire Not Drawing 23 3980 Sat Nov 11, 2006 9:26 am
"Heatprofile" radiant skirting heaters - any exper 12 2080 Tue Sep 12, 2006 11:30 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
