Just a quick one, I forgot to note the Short circuit capacity of the MCB's today and checked through the OSG, would it be fair to assume that a type B MCB is 6KA and a type C MCB 10K or can they both vary?
mmm they are wylex MCB's some 3 phase and some single phase, the only writing on the MCB was NSB-B and the current rating on the 3 phase MCB's. The figure must be written on the side which is a little inconvenience.
I wasn't sure if that was the only difference between NSBs and PSBs ,I wasn't sure if NSBs were ever intended t be used in 3ph boards, I know the NSB blanks don't fit 3ph boards properly (have been forced to use them as short term measure)... but then the NSB blanks are pretty pants all around!
