I have a worcester combi boiler and a few weeks ago the pressure started dropping. I have to top it up every morning and by the following morning the pressure has dropped from 1.2bar down to 0.5bar.
I had this problem once before and found that the cupboard under the sink was always damp and took out the floor and found one of the pipes from a radiator to a splitter pipe was leaking. Got that repaired and had been fine for the last 5 years or so. Lifted the board up again and all the pipes are dry so the leak must be elsewhere.
* No damp spots in the ceiling so the leak must be downstairs.
* Boiler auto air vent and other internals are dry so no leak from the boiler.
* Overpressure outlet is dry
The house is about 20 years old with 3 radiators upstairs and downstairs. 10mm microbore. What I can see under the sink the microbore seems to be encased in plastic I assume to protect it from rubbing.
So at this point I am thinking it must be a leak in one of the pipes running from the under the sink to each of the 3 downstairs radiators (kitched, front room and porch).
Any ideas for diagnosing furthur other than start lifting the floorboards. The kitchen would be a pain as its laminate.
