DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Cold water overflow pipe dripping, some mornings
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
spice28
from United Kingdom
PostPosted: Mon May 04, 2009 8:01 am Reply with quote
I would appreciate some advice please.
Basically, the overflow pipe from the cold water tank in the loft (I think) is dripping sometimes. We wake up (7-8am) some mornings to find a puddle on the ground under the overflow pipe from the loft. The water is splashing up on the wall so it must initially be running out but we have only ever seen it drip. The drips get less frequent over an hour or so until they stop altogether. This only happens about once a week or so.
So, what could be causing this. I know that dripping can be caused by a faulty valve in the ball cock but the drip is not constant so I'm not sure if it is the valve. It seems to happen around the same time the gas central heating comes on but again that comes on every morning.
Any help would be gratefully appreciated.
Back to top
 Alert Moderators
swbjackson
from United Kingdom
Thanked: 148 times
PostPosted: Mon May 04, 2009 8:06 am Reply with quote
Could be a faulty ball valve letting by over night when the pressure is higher. As it happens as the heating is starting it may be expansion of hot water in the cylinder causing the level to rise slightly in the cold water storage cistern. The level in the cistern should be low enough to accommodate this expansion. If the level in the cistern is too high the ball valve may just need adjusting or it may be faulty.
Before you run off any water in the morning go up and have a look. If the float is partially submerged there is a fault. Check the float is not partially full of water, if it is intact the ball valve is letting by and needs refurbishment/replacement.
Back to top
 Alert Moderators
holty
from United Kingdom
Thanked: 925 times
PostPosted: Mon May 04, 2009 10:28 am Reply with quote
as swbjackson, i would agree its the ball valve letting the smallest drip bye,till it gets to the point when it gets near overflow conditions the expansion of the dhw will cause the overflow.
Back to top
 Alert Moderators
spice28
from United Kingdom
PostPosted: Mon May 04, 2009 1:02 pm Reply with quote
Thanks to you both for your helpful replies.
Guess I'll be getting a new ball valve then!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Triton Ivory II 9.5kw not heating water in mornings 3 40 Fri Jul 20, 2012 11:51 am
Hot water but central heating only works in the mornings . 16 460 Wed May 14, 2014 7:53 pm
Bedroom radiator works some days or just some mornings 6 280 Thu Oct 21, 2010 8:14 am
Overflow pipe dripping cold water from unvented system 9 160 Sat Jan 12, 2013 9:17 am
Cold water tank overflow dripping like mad 9 2920 Wed Dec 19, 2007 11:16 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
