DIYnot
Local | Network
   DIYnot > Forums
Local | Network
conservatory lead flashing
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
Author Message
rizred
from United Kingdom
PostPosted: Tue May 05, 2009 11:44 am Reply with quote
Hiya,
I am installing a new selfbuild conservatory soon and am after some Lead advise,
I've had a look around on here and found that i should have approx 20mm in the wall, a 150mm upstand and 100mm down over the roof - does this sound about right? I have also read that the lead shouldbe in lenghts no longer than 1500mm, is this really neccesary for a 3000mm wide structure?
Also, how far past each side of the roof do i need to go? and do the vertical ends just "stop" or should they be cut in down the wall as well?
D
Back to top
 Alert Moderators
justlead1
from United Kingdom
Thanked: 8 times
PostPosted: Tue May 05, 2009 11:55 am Reply with quote
Hi' 30 mm chased in wall, say 100mm upstand and 150 mm down slope, 1500 mm max for code 4 sheet lead. Lap on joints min 100 mm. For a 3m run, three pieces will be easier to fit, the over lap at ends about 150mm. Good Luck
Back to top
 Alert Moderators
rizred
from United Kingdom
PostPosted: Tue May 05, 2009 12:30 pm Reply with quote
Thanks for the quick response!
Can i assume that you buy standard width rolls? if so, what would you recomend? And are they set length rolls? What size roll would you recomend and what price would this be roughly?
As the old saying goes "if you need lead information, ask a cornishman"
Cheers
D
Back to top
 Alert Moderators
alastairreid
from United Kingdom
Thanked: 703 times
PostPosted: Tue May 05, 2009 4:59 pm Reply with quote
Back to top
 Alert Moderators
justlead1
from United Kingdom
Thanked: 8 times
PostPosted: Tue May 05, 2009 5:31 pm Reply with quote
Hi. I can supply if your pushed, but it would need to be collected. 270mm wide and 3.6 m in length (cut into 1.2m lengths) Approx 44-00 including vat.
I am in Wadebridge, North Cornwall.
Back to top
 Alert Moderators
rizred
from United Kingdom
PostPosted: Wed May 06, 2009 7:57 pm Reply with quote
Hi Justlead1,
i've sent you a message via here and email..........
D
Back to top
 Alert Moderators
rizred
from United Kingdom
PostPosted: Mon May 18, 2009 12:09 pm Reply with quote
To Justlead1,
Thanks for your help with the lead and thanks for hanging around for me!!
I havent fitted the lead yet, i want to take my time with it to make sure i get it right so have used the temporary flashing kit and will put the lead over this when it stops bloddy raining!!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
Looking for advice on lead flashing for conservatory please 16 460 Tue Jan 07, 2014 7:40 pm
lead flashing a new timber frame conservatory 3 1160 Sat Jul 15, 2006 12:08 pm
WHAT NUMBER & DEPTH LEAD FLASHING FOR CONSERVATORY ? 3 1040 Fri Oct 20, 2006 8:23 pm
Leaky conservatory, damaged flashing - emergency! 8 200 Tue Dec 24, 2013 9:58 am
Flashing conservatory roof to UPVC Claddding 2 820 Sun Sep 26, 2004 1:41 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
