DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Adding a ring main circuit
This topic originated from the How to page called Extending a ring circuit using existing sockets
Click here to return to the page called Extending a ring circuit using existing sockets.
  View previous topic :: View next topic
Author Message
paul_w_matthews
from United Kingdom
Thanked: 0 times
PostPosted: Thu Dec 09, 2004 5:17 pm    Post Subject:
Reply with quote Thanks
Hi hope you can help?
I am wanting to add a ring circuit (approx 4 sockets). Currently someone already wired a double socket outlet directly from the fuse box using just a single Twin and earth 2.5mm cable, connected to the fuse that is used for the existing ring main. If I use that to go from and go on and create a ring with an additional 4 socket outlets can I just end that ring back by running from the last socket in the ring a twin and earth cable back to the fuse box and connect where the current one is connected ?, or does it need to have its own fuse? Guess difference is a new ring on existing ring main fuse or new ring on its own fuse. Hope you can help icon_smile.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Thu Dec 09, 2004 7:25 pm    Post Subject:
what you appear to have is a ring with a spur.
why not just extend the ring, much easier (assuming floor area is less than 100m)
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
paul_w_matthews
from United Kingdom
Thanked: 0 times
PostPosted: Thu Dec 09, 2004 7:37 pm    Post Subject:
thanks for the reply
If this is not the ring and as you say a spur off either the existing ring or just seperately connected to a different fuse - then guess i can either create a new ring with its own fuse, or can I disconnect the tails from one of the existing ring mains at the consumer unit - connect into a junction box and then run from there into the new ring and finally back into the existing ring...hence break the existing ring extend it and bring it back to the existing ring main fuse connection.. hope I make that clear enough?
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 0 times
PostPosted: Thu Dec 09, 2004 7:39 pm    Post Subject:
you could do that, however make sure the floor space is under 100M^2
if there is a space available, i would make it into a new ring
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Thu Dec 09, 2004 7:47 pm    Post Subject:
two rings on a fuse is not a recognised cuircuit design but its not in any way dangerous. As for regs compliance once you get outside of recognised cuircuit designs the regs become quite open to interpretation. I know at least one sparky who failed a cuircuit in a pir only to be overridden by the niceic.
if you have a spare fuseway availible then don't put two rings on the same fuse but if you don't then to be frank putting two rings on a fuse isn't dangerous and bringing yoru installation up to date with current regs would probablly require a new CU anyway for rcd protection reasons
Back to top
 Alert Moderators
paul_w_matthews
from United Kingdom
Thanked: 0 times
PostPosted: Thu Dec 09, 2004 8:12 pm    Post Subject:
Thanks for the quick response
Ok so last word from me... so just to be clear I have a choice - if I can connect new ring to its own fuse in the consumer unit, or if not break the existing ring removing the taisl from the consumer unit add a junction box and extend out to the new ring and back if not more than 100M^2 floor space. Otherwise have two rings in one circuit and one fuse....
again appreciate all your help.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Thu Dec 09, 2004 11:03 pm    Post Subject:
no, have one very big ring one fuse it is the best / safest way
try a search its actually quite easy
__________________
Forum = Opinions
Back to top
 Alert Moderators
brown-nought
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 10, 2004 12:15 pm    Post Subject:
Mr Jobsworth inspector might consider that a bridge. It all depends where you test from.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Fri Dec 10, 2004 5:20 pm    Post Subject:
Mr jobsworth inspector would have failed it on lack of rcd ANYWAY
and when mr electrican comes to bring the install up to current standards he will probablly put in a new CU anyway.
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 10, 2004 5:25 pm    Post Subject:
who would be 'Mr Jobsworth'
Back to top
 Alert Moderators
RiRa
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jun 16, 2009 10:13 am    Post Subject:
ring mains
Just in case anyone is looking at this question now, it's worth pointing out that the "100m2 rule" was at that time only a 'guideline', and today one should not use it. Calculate each case using Appendix's in IEE 17th ed. Also, whereas in 2004 you might have got away with bunging more than one final circuit on 1 way, today that's is a definite 'no-no' :- regs say 1 final circuit per way.
So in this particular case you would have to either extend the ring [if your calculations allowed that] or create a new ring, on a separate way.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Jun 16, 2009 2:45 pm    Post Subject:
Re: ring mains
Welcome RiRa.
I don't expect Paul Matthews is still trying to decide what to do.... icon_wink.gif
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Adding a socket / extending the ring main 8 880 Sat Jan 20, 2007 6:17 pm
Adding a Ring Main 15 1120 Sun Feb 22, 2009 5:49 pm
Adding a FCU spur to ring main for a heater 5 200 Fri Apr 10, 2009 11:24 am
Adding sockets to a ring main 9 1120 Sun Aug 13, 2006 9:09 pm
Adding sockets to a ring main 3 560 Mon Jan 08, 2007 3:11 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
