Boiler burner light not coming on/no HW or CH help.
2 Nov 2007
Manchester
Hi, Im hoping someone can help me.
I have a Chaffoteaux Britony Combi 80 and when I try for HW or CH the boiler doesnt fire up and I cant hear a spark generation. The pump runs and it sounds like it usually does but there is no flame or orange light coming on and no HW or CH.
Has anyone got any ideas what it could be or think I need to PCB replacing?
Thanks.
The flow switch.. is that the same as the DHW flowstat? If it is I got that replaced last month.
Is the fan pressure switch easy to check?
Ah yes Ive found them. The left hand size flow switch (DHW) has been replaced not long ago. Could the other flow switch also need replacing?
And also would you try replacing the pressure switch before the PCB?
Cheers for the help. Ive got a guy coming round this afternoon. Lets hope it doesnt cost me a bomb!
Turns out its the fan.
If I hold the inner casing open slightly the boiler ignites and works fine so this would suggest the fan isnt working correctly?
Ive had a look at replacing one and it looks pretty easy. Few screws/connections, twist it out and pop the new one in. Is there anything I need to know or can It be replaced this easily?
Thanks,
na
what did the guy that came have to say :?:
and stop messing with things you don't understand :evil:
Thats what he did.. he held opened the inner casing about 2inches and the boiler ignited. He said this was due to the fan not working correctly and that I need a new fan.
I found one on ebay so im thinking of fitting it myself.
