DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Painting above conservatory
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
  View previous topic :: View next topic
Author Message
Joe100w
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 11, 2009 1:40 pm    Post Subject:
Reply with quote Thanks
Hi, I have been asked to paint the ouside of a house. However, there is conservatory at the back of the terrace house about 20 feet long and 11 feet wide. The conservatory roof is one large sloping area. My problem is how to get a ladder on top to paint the walls.
All suggestions welcomed.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gday2uk
from United Kingdom
Thanked: 7 times
PostPosted: Mon May 11, 2009 2:23 pm    Post Subject:
A good suggestion would be a scaffold.
Back to top
 Alert Moderators
dave1953
from United Kingdom
Thanked: 2 times
PostPosted: Mon May 11, 2009 6:29 pm    Post Subject:
If it's Pvcu conservatory take out the relevant panels to give you access, if it's wooden glazing bars then scaffold for safety icon_eek.gif
Back to top
 Alert Moderators
Joe100w
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 11, 2009 7:16 pm    Post Subject:
I think removing of the Roof glazing panel will be the easiest way to tackle this.
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 48 times
PostPosted: Mon May 11, 2009 7:27 pm    Post Subject:
I was a bit surprised to see our cons, fitter scramble up on the roof & just walk about on it without a care when we had to call him back to do some remedial work on the finals; that’s not just the glazing bars but the panels! When I asked him about it, he said it really wasn’t a problem as long as your not a F** Bas****; which he wasn’t!
Our cons roof is 40mm, 5 wall poly & whilst I’m certainly not going to recommend you try it, they are probably a lot stronger than you would think; point loads may be a problem though, hence the FB comment! If the cons. is more than a year or so old, sliding the panels out will probably damage the glazing bar seals & lead to leaks; entirely at your risk but if you put some boards & a ladder up there to spread the load you may be OK ---- but test it first!
__________________
Richard C
Back to top
 Alert Moderators
Joe100w
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 11, 2009 7:51 pm    Post Subject:
After the posted that I will remove the glazing, I remembered doing some work on a similar roof where the panels has slid down and will not go off. Removing of the beading resulted in them breaking and splitting. Also the new beading was not compatible with the old ones and had to be replaced completely - both the metal base and plastic cover.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
painting above a conservatory 5 400 Sat Sep 29, 2007 12:51 pm
Cold Conservatory 5 280 Sun Nov 23, 2008 2:05 pm
Painting bare doors from scratch 2 300 Wed Mar 05, 2008 11:08 am
Aluminium door painting 2 340 Sun Mar 02, 2008 11:32 am
Painting a brand new front door (Wood) 8 640 Thu Mar 06, 2008 6:01 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
