DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Central heating blockage?
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
bcutts
from United Kingdom
PostPosted: Sun Jan 19, 2003 12:31 pm Reply with quote
Having HUGE problems with my central heating.
Yesterday I wanted to flush the system and add corrosion inhibitor. I opened the drain cock at the bottom of the system and it drained away quite happlily whilst filling the header tank in the loft from the cold water supply. I then added the contents of the inhibitor an allowed it to be drawn into the system.
After a couple of minutes, the flow from the drain cock stopped and the system now refuses to fill from the header tank.
Could something have been drawn into the system and caused a blockage. If so, where is this likely to be?
I've tried reverse flushing the system from a hose connected to the drain cock but all that happen is that afer a while, the water flows out of the system expansion pipe into the header tank.
Somebody please help as my wife is getting cold & angry icon_wink.gif !!
Brian
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Sun Jan 19, 2003 1:06 pm Reply with quote
I am not a plumber or heating engineer, but as you say id does seem probable you have a blockage.
Could you not "connect" the hose to the "input" from the header tank and Tempoary block the expansion pipe, if it wont go one way perhaps it will go the other
Back to top
 Alert Moderators
simon
from United Kingdom
PostPosted: Sun Jan 19, 2003 2:24 pm Reply with quote
have you opened any/all bleed valves on the rads and the system bleed normally at the highest point but may be by the cylinder?
Back to top
 Alert Moderators
bcutts
from United Kingdom
PostPosted: Sun Jan 19, 2003 4:35 pm Reply with quote
I've tried opening several bleed valve on upstairs and downstairs radiators at the same time. I also opened the valve on the pump to get it to fill with water so that I could perhaps run the system and clear the blockage but to no avail.
I'll try connecting a hose to the inlet for the system and try flushing the other way.
Will it harm the system if I plug the expansion overflow when I try flushing again?
Regards,
Brian
Back to top
 Alert Moderators
simon
from United Kingdom
PostPosted: Sun Jan 19, 2003 5:11 pm Reply with quote
I'm not sure exactly what you've done.You tied off the central heating tank (the small one) in the loft right?,then drained down the radiators through the lowest drain off cock so there's only an inch of water in the small tank.Then you closed off the drain off and opened a bleed valve on a rad went back in the loft untied the ballcock and mixed your fernox (or whatever) with the water as the tank filled?
I presume this is the way it went if not can u explain how you did it.Also are you sure you opened the system bleed a short vertical pipe with a small screw cap on it?,if u undid this and no water or air came out get a small nail or similar and gently release the blockage or make sure the rubber seal is not sticking blocking the hole.
Back to top
 Alert Moderators
simon
from United Kingdom
PostPosted: Sun Jan 19, 2003 5:16 pm Reply with quote
By the way it won't hurt to block the vent pipe just to flush the system
Back to top
 Alert Moderators
bcutts
from United Kingdom
PostPosted: Sun Jan 19, 2003 10:41 pm Reply with quote
Simon,
Yes I did pretty much as you suspected - other than the fact that the fill for the expansion tank has a stop-valve so I didn't havce to tie up the ball-cock.
I blocked off the expansion vent pipe and tried reverse flushing with all the radiators closed and after a few minutes, the water started to fill the expansion tank. The system now seems to fill from the expansion tank and I've bled the pump and the radiators and got the system running.
I can't find the vent pipe valve you mentioned. As the system is still somewhat noisy - lots of water gurgling, I may need to bleed that as well - where in the system would I find it - near the pump output?
Back to top
 Alert Moderators
simon
from United Kingdom
PostPosted: Mon Jan 20, 2003 12:02 am Reply with quote
Glad you're sorted.As it's in you're own house I'd bleed all the rads tomorrow night and then again next week.
Technically the system bleed valve should be on the highest point of the system ie by your cold water storage tank in the loft somewhere but they're often by the hot water cylinder.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Noisy Central Heating Pump 5 1380 Sat Feb 22, 2003 7:07 am
Size of copper pipng for central heating 2 1100 Fri Feb 14, 2003 3:57 pm
Central heating venting through expansion pipe 2 1060 Wed Feb 26, 2003 9:48 am
Central Heating 8 900 Sat Mar 22, 2003 6:15 pm
Central heating wiring diagram 12 85620 Mon Mar 24, 2003 8:08 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
