Joined: 31 Oct 2007 Posts: 218 Location: Edinburgh, United Kingdom Thanked: 1 time
Posted: Fri May 15, 2009 11:52 am Post Subject:
PRV and Pressure vessel
A friend of mine is on his third heat exchanger on a Sabre combie. Volkara has advised him to install a pressure reducing valve and a pressure vessel on his cold water main. What is the correct order to install these components? ie. Stop cock - pressure vessel - pressure reducing valve. His mains pressure is at 3.5 bar, What pressure should he set the PRV to and pressure vessel charge.
Joined: 24 Apr 2009 Posts: 321 Location: Durham, United Kingdom Thanked: 3 times
Posted: Fri May 15, 2009 11:01 pm Post Subject:
The boiler quotes a maximum 6.0 bar mains inlet.
What I suspect is there is a loose jumper stopcock or non return valve before the boiler. This is allowing pressure to build too high as there is no expansion available.
A pressure reducing valve above the main stopcock (to maintain balanced pressures), and on the boiler inlet, fit a single check valve followed by the mini expansion vessel.
Thankyou, will tell him.
And yes they were all warrantee repairs, But they have stated they will not repair it again unless he takes these steps.
Thankyou all, Sorry for the delay in replying I was away the weekend.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
