DIYnot
Local | Network
   DIYnot > Forums
Local | Network
uPVC Door Handle Prob
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
ScottishGasMan
from United Kingdom
Thanked: 168 times
PostPosted: Fri May 15, 2009 4:07 pm Reply with quote
Hi, Tring to sort my mates door handle for him cos I thought it was the same as last time (loose bit on the handle its self) but it looks more complicated.
Problems is, Door locks and unlocks fine, but on pulling the handle down the (dunno the name of it) catch bit that should pull in when the handle turns only moves in a little (not enough to open the door)
Took the handle off and the square shaped bolt that goes from outside handle to inside is moving fine so must be something right inside the handle/lock.
Can anyone shed some light on the most likely cause and if its a repair or replace parts job?
thanks
SGM
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
uPVC door handle problem! 2 500 Mon Aug 24, 2009 4:31 pm
Cant find door handle size for upvc door 4 80 Wed Aug 29, 2012 8:17 pm
Upvc door handle 3 80 Wed Mar 14, 2012 7:17 pm
Replacing glazing and handle in upvc door 7 1600 Thu Aug 17, 2006 12:41 pm
Loose handle on upvc front door 2 1181 Mon May 11, 2009 9:57 pm
DIYnot
