Hi there, in July 2008 I had an intermittent problem with my 9448+ where the tamper alarm would trigger (with the alarm set or not set).
As I was going away on holiday I did the following:
1) replaced the battery with a Yucel one from my local alarm supplier
2) linked the global tamper in the panel (i.e. linked the two A/T terminals)
3) linked the 0v and TR terminals in the panel (to eliminate the bellbox)
4) and I think I linked the 0v and TR terminals in the external sounder as well (a Westech Armourflash)
Anyway, all has been fine over the last year until about 2 am this morning (alarm not set) the alarm triggered with the tamper light on again (internal sounder, I did not notice if the external one was sounding)
It will reset OK and has not gone off since the early hours. As I am soon to go on holiday (it always happens before going away!!) I checked the panel tamper switch (engineer access walk test) and it seems OK.
Any ideas what could be causing this
thanks
PS I fitted the alarm system about 10 years ago and it has been fine, apart from this problem!
thanks
