Good afternoon all, new to the forum so hello!
I'm having some issues with my dishwasher where it runs for a few minutes, appears to be filling and emptying, but then stops flashing fault code E2.
I have done some reading on the forum and completed a number of the trials as recommended, but have had no joy in getting things up and working again.
So far, I have dismantled the inside as far as I can and there is no water inside.
I have disconnected all the plumbing to check for blockages, but all appears to be fine. The inlet from the mains doesn't seem to be fitted with an Aquastop, so perhaps that is somewhere else?
After putting it back together and trying to run it again, it seemed to take a lot longer to reach the same conclusion (I assume this is the 3 fills before issuing the fault command), but now it shows error code E1.
I see that the most common issues are to do with the float and the pressure inlet, which appears to be mounted under the dishwasher, but having looked, there is nothing under mine - simple question, but do I need to remove the bottom panel to get to this?
In addition, the reset option of turning on, pressing the mode button 4 times etc doesn't work with mine ... Is there another sequence for this model?
Am running out of options now, so wanted to ask if anyone has any ideas before I call the engineer?
The machine is 4 years old if that makes any difference?
Phil
Phil
