joist hangers for decking
8 Mar 2009
Powys
Hi all quick question about joist hangers are they ok to use on decking i am building some raised decking next up against a hedge so it be difficult to screw the joists from the back side so i was thinking of using these any advice please
How about making the frame first then moving it into position ?.
Then you only need to bolt it to your posts.
I want to build a Hexagonal deck, i thought i remembered seeing a set of sort of galvanised bracket for doing this, or was i dreaming
Josher
well iv used the joist hangers what i did was electric planed a grove deep enought for the straps to sit in worked a treat and allowed for the screw heads decking sat flush with the joists then sweet
