Code change for Concept System alarm
Hi all, I need to change the back up battery in my concept alarm and wondered what was the best way to go about it?
The main control box is in the loft and the keypad is in the kitchen, at the moment I need to use the 0123 code after a power cut so hopefully a new battery in the main control box will fix this. I don't want to set it off and be unable to reset it if there are tamper switches or whatever in the control box so any advice would be gratefully received.
Thanks in advance.
RG
easy one;
press the PROG button
then enter 0123
TAMPER light should show
change battery
put cover back on
press RESET
all done
Oasis
Hi again,
Prog, 0123 didn't work but Prog and then my code did so all good.
It has a Yucel Y2.1-12 battery and I just wondered what the difference was between that and the NP2.1-12 before I order one?
Thanks again... :)-)
