Tatty table
17 May 2008
I have a teak table that is 4 yrs old, but has never been protected with anything. It is now silver/grey and slightly rough.
What should I use to bring it back to life. I don't want it to look too new.
lightly sand to get rid of the rough bits?
it will weather to silver / grey anyway, the only way to stop it is to stain it or seal it I suppose?
Same as ours. Just sand it lightly to get smooth and then use Teak oil. If you use a stain you will be doing it forever and more than likely end up with cracked / flaky surface where the stain comes off eventually
I used a pigmented teak oil last year and that already came off slightly flaky so i would recommend just teak oil. Make sure the wood is very clean and dry before you do it though and put on a few thin coats
That's the way it's supposed to go :D Just a rub down and some teak oil as previously suggested is fine.
