Ariston 1535 washer error code 10 flashes
28 May 2009
Carmarthenshire
This washing machine works until it drains, it does drain but then the pump continues to run and the dial clicks around on its own it gives an error code of ten flashes.
10 flashes mean presure switch stuck ,clean filter and refit plugs on pcb ,if it still happens you need a presure switch and poss pcb .
I have checked the pipework is clean, a gentle suck on the pressure switch produces a little click and all the wires are fitted to the pcb board so I guess it is going to have to be a new board. 40 years ago my first job was being a Bendix washing machine engineer machines bolted to the floor and a spin speed of 350 rpm. They were simple and I understood them and know electronics. They did break down nice and regularly though. cheers thanks for the advice.
