Heating Switched Off But Radiators Hot!
ijc
17 May 2005
Sheffield
Hi
I have an Ideal condensing combi boiler, which has been faultless since bought a couple of years ago.
However, my radiators have started to get hot despite the heating being switched-off. This is especially noticeable when the hot water is running.
I know the pump is supposed to kick in of it's own accord, even if the heating is switched off, but it shouldn't be carrying hot water to the radiators!
All I can think to do is switch the system off for a night and hope for a miracle, but any thoughts or suggestions welcome.
Thanks in advance
Ian
Do we assume it is an Isar, or perhaps a Mini?
The diverter valve has stuck in mid position and letting by to the heating circuit is the most likely cause.
Search on here, it has been covered many times ;)
Hi
Honest, I did search the FAQs and stuck a few key words in, but didn't find anything!
It's an Isar - something tells me you've been here before!
Common problem is it? Presumably not a DIY job...
Thanks for your response - much appreciated,
Ian
Unfortunately most of us on here have :cry:
When you run a hot tap and 'd' is displayed, feel the left hand pipe. If it gets warm/hot, then yes it's the DV.
You could just remove the head off the valve and try pushing the pin in a few times. It may just release it.
Otherwise it will need a new DV.
You may find someone local to do it, but as always I recommend Ideal in to do it on a fixed price repair. I can't replace one of these for the price they charge :rolleyes:
Thanks again.
Your suggested symptoms are spot-on. I'll have a prod at the valve and cross my fingers. Failing that I'll give Ideal a call.
Cheers.
Ian
PS - hope you're an Everton fan!
