DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
ceiling light fitting
This topic originated from the How to page called Connecting a flex to a bulbholder
Click here to return to the page called Connecting a flex to a bulbholder.
  View previous topic :: View next topic
Author Message
bobo
from Ireland
Thanked: 0 times
PostPosted: Tue Dec 14, 2004 1:34 pm    Post Subject:
Reply with quote Thanks
I am trying to fit a ceiling light to my ceiling. The mains cable running through the ceiling joist is too short to reach the ceiling light. The light fitting has a 3 block strip connector to connect the mains to it. Is it OK to feed the flex from the light fitting up through the joist and connect it to the short mains cable. This way the conection will be made in the ceiling cavity. I can access the cabling from the floor boards in the bedroom. There is no insulation i the ceiling cavity so there is space for the connection to be made.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
mapj1
from United Kingdom
Thanked: 0 times
PostPosted: Tue Dec 14, 2004 3:15 pm    Post Subject:
It would be better to use a proper joint box, and lengthen the cable, or if you must use choc block, then put it in some kind of box to protect it.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
ceiling rose flush fitting light 2 660 Mon Oct 24, 2005 11:12 pm
Changing a ceiling spotlight back to a pendant light fitting 3 2320 Mon Feb 06, 2006 7:05 pm
Heavy ceiling light fitting - what fixing? 22 3840 Sun Sep 25, 2005 6:40 am
New Light Fitting with different connections for ceiling 5 560 Sat Feb 03, 2007 1:15 pm
Want to change a ceiling light fitting 5 2640 Fri Apr 23, 2004 8:49 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
