Problem with Aqualisa Quartz digital shower
31 May 2009
Oxfordshire
My shower doesn't switch on as it should. I have changed shower hose and it did help but not any more. I believe it is the controle and wonder if anybody knows if you can repair it (service it) and how to get it off the wall.
If changing the hose made a temporary fix then the inlet filters on the pump/mixer may be blocked.
The pump/mixer is usually mounted in the loft, in an airing cupboard or under the bath. Turn the power off first and expect some retained water to spill.
either does or it don't
whats it not doing that it should ?
hows that help switching a shower on ?
why
take it its a early one with no warranty left on it then.
