DIYnot
Local | Network
   DIYnot > Forums
Local | Network
How to stop door slamming
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
geojay
from United Kingdom
PostPosted: Wed Jun 03, 2009 2:37 pm Reply with quote
The front door of my flat is susceptible to slamming. The door is between my flat and a communal stairwell. The door is fitted with a concealed chain type closer (I'm not sure if it has a proper name...) between the door and frame. The combination of the concealed closer and airflow (I always keep the kitchen window open and there's usually a window open in the stairwell) means the door slams if you don't hold it.
Any suggestions on how to stop the door slamming? I know to hold it but guests and friends often forget and the resultant slamming (understandably) annoys the neighbours. I also appreciate that the closer is there for fire-safety reasons...
Back to top
 Alert Moderators
stephenf8542
from United Kingdom
PostPosted: Wed Jun 03, 2009 3:00 pm Reply with quote
Change it to an overhead closer then you can adjust the speed it closes at
Back to top
 Alert Moderators
geojay
from United Kingdom
PostPosted: Wed Jun 03, 2009 3:07 pm Reply with quote
Looking more at the subject makes me think a closer is no longer required for fire reasons... In that case I'm tempted to remove it completely. It's my front door so it's not like I leave it open other than to walk through it!
Opinions?
Thanks!
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1255 times
Fit a dictator device to the top of the door.
This is a small hydraulic cylinder and wheel which catches the door before it hits the frame, and causes it to close slowly
Edit
Front doors in flats above 2 storeys should have a self-closing device
Back to top
 Alert Moderators
freddymercurystwin
from United Kingdom
Thanked: 1486 times
PostPosted: Wed Jun 03, 2009 3:10 pm Reply with quote
Or one of these http://www.doortech.co.uk/slam-stop.htm not pretty
Back to top
 Alert Moderators
Symptoms
from United Kingdom
Thanked: 50 times
PostPosted: Wed Jun 03, 2009 9:21 pm Reply with quote
jay - your mystery door closer is a Perko door closer and is one type of device that had to be fitted (and remain fitted!!!) to your type of fire door ... you should not remove it. Fit a door damper (^woody^'s DICTATOR door check {google for pic & info} or similar) as this will solve the problem and keep you legal.
Back to top
 Alert Moderators
geojay
from United Kingdom
PostPosted: Thu Jun 11, 2009 4:56 pm Reply with quote
I've now tried something similar to the slam-stop but instead of slowing down the closing of the door, it actually stops it if it's going too quickly and doesn't then release it. It's something like the mechanism of a car seat belt reel, the pressure needs to be released before the door will close.
The dictator looks perfect apart from the price, the cheapest I can find them for is ~65 and that's a lot more than I want to spend on stopping the door slamming...
Any more suggestions?
Many thanks!
Back to top
 Alert Moderators
Danni39
from United Kingdom
PostPosted: Sun Apr 24, 2011 6:37 pm Reply with quote
Hi there,
I'm wondering if you're able to help. I live in a tiny bedsit in Kent. Recently a neighbour moved into the bedsit next to me. During the night she often goes in and out of the bedsit, and although she doesn't slam her door. She closes it in a way, that there is always a bang at the end. Admittedly it's not very loud, but each time it happens, this bang wakes me, not helped by the fact I'm a light sleeper. I have asked her to close the door quietly, but unfortunately things haven't improved. I know this can be done, as I never heard my previous neighbour who lived there for over 8 years. This has been going on for weeks now, and I'm feeling very sleep deprived.
Would I be able to be a device that would stop the door banging? Or any other suggestions would be greatly appreciated.
Many thanks
Daniela
Back to top
 Alert Moderators
Alarm
from United Kingdom
Thanked: 529 times
PostPosted: Sun Apr 24, 2011 8:06 pm Reply with quote
Concealed door closers (Perko and such) are not very adjustable and air pressure can alter the characteristics.
A Dictator is really for heavier doors and thus not suitable.
A main door would benefit from a LCN door closer but not cheap at 240 ish.
For smaller internal doors a well adjusted overhead closer is best.
A cheap but reliable one is the draper one.
http://www.google.co.uk/products/catalog?q=cheap+door+closers&oe=utf-8&rls=org.mozilla:en-GB:official&client=firefox-a&um=1&ie=UTF-8&cid=1483702333936215135&sa=X&ei=1IG0TZ-sIYSp8AP2_aCWDA&ved=0CIQBEPMCMAc#cond=1
Although Yale and several others do similar. Just fit them correctly and that should be it.
Back to top
The following user says thank you to Alarm for this useful post:
Danni39 (24 Apr 2011)
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
stop doors slamming 3 180 Thu Jun 09, 2011 12:59 pm
uPVC door - slamming! 8 1320 Wed Sep 01, 2010 2:20 pm
fire door slamming has loosened frame 4 980 Mon Apr 25, 2005 10:56 pm
Closers slamming 6 80 Mon May 27, 2013 10:31 pm
How to stop draught at door seal........ 2 100 Thu Sep 13, 2012 8:32 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
