hot water storage tanks
13 Oct 2008
Glasgow
any info would be grateful guys. i want to put a hot water storage tank above th sink in our factory, is it just a straight forward connection from the mains to the valve that is needed, is there any difference between vented and unvented ???
also when i am changing tap washers on the hot tap is it necessry to turn the heating off if i'm turinng the main stopcock off ??
thanks
what as in a copper cylinder.
what valve ?
vented useally gravity, unvented is useally at mains pressure and you need to be g3 unvented registered to fit or work on one.
what on a combi system if your talking about shutting the stopcock ?
and no heating will be fine.
thanks forthe reply, basically i want to install an over the sink hetrae sadia water heater, there is a valve that comes out the bottom of the case one end is connected to the inside of the tanks so i assume i just connect the other end of the valve to the water main ???
and when working on taps or showers do i have to turn the boiler off if i m closing the main stopcock ???cheers
now you say.
well sort of but follow the instructions.
you may need a pressure reducing valve, and expanssion vessel etc.
and you need a pressure relief valve pipework
what model unit is it your fitting ?
if its a combi boiler i useally just turn it off on the front panel.
saves any problems.
it's just an over the sink water heater that holds 7 litres of water, it's for doing the dishes etc, didn't think it was a complicated as pressure relief valves and pressure reducing valves etc ???
cheers
I now going out to fit the exact same one, heatrae express 7, 3KW.
Piece of pee to fit, you should have no problems ;)
