DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Plastering over lead painted walls
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering
  View previous topic :: View next topic
Author Message
NatB
from United Kingdom
Thanked: 1 time
PostPosted: Fri Jun 05, 2009 12:03 am    Post Subject:
Reply with quote Thanks
Hi, I've started to prepare a room for plastering, on removing the wallpaper we've found the original lead painted wall. The plasterer we had lined up has said he won't plaster over this as it will blister, a test patch proved this.
Is their any sealer or primer available that is designed to seal the lead prior to plastering?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
roughcaster
from United Kingdom
Thanked: 49 times
PostPosted: Fri Jun 05, 2009 7:56 pm    Post Subject:
Re: Plastering over lead painted walls
I've never come across that type of paint on walls. I know that old distemper blisters when wet,, is this paint similar? Pardon my ignorance on this one. icon_rolleyes.gif
Roughcaster.
Back to top
 Alert Moderators
NatB
from United Kingdom
Thanked: 1 time
PostPosted: Fri Jun 05, 2009 9:34 pm    Post Subject:
When I say lead paint, it's an old lead based paint. This was under a ton of old wallpaper and is various colours. The problems start pretty quickly after the plaster or bonding is put on, very quickly the finish begins to blister but small blisters.
The plasterer just told me it was lead paint and he won't go over it as it will do exactly what he showed me with a small section. The only help he gave me was to say he had heard there was a (german?) sealer which may be the solution but he can't give me any more details than that.
Back to top
 Alert Moderators
roughcaster
from United Kingdom
Thanked: 49 times
PostPosted: Fri Jun 05, 2009 9:44 pm    Post Subject:
When you say the plaster blistered, did you mean the plaster itself blistered, or the paint blistered underneath the plaster, as happens with old distemper?
Roughcaster.
Back to top
 Alert Moderators
NatB
from United Kingdom
Thanked: 1 time
PostPosted: Fri Jun 05, 2009 10:05 pm    Post Subject:
The plaster (and bonding in another area) blistered itself, like tiny balls of dust but are in fact blisters.
Back to top
 Alert Moderators
roughcaster
from United Kingdom
Thanked: 49 times
PostPosted: Fri Jun 05, 2009 11:16 pm    Post Subject:
I'm personally baffled with this one Nat. What happens when you wet an area with a brush, or spray some water on it? Try it and see, and if possible show us a picture. If it does react to the water, then you might be able to scrape it off while it's damp, (with great care, mask, gloves etc), and that would get rid of the stuff altogether, rather than sealing it in. A lot of work maybe, but it might do it,,,, fingers crossed.
Roughcaster.
Back to top
 Alert Moderators
NatB
from United Kingdom
Thanked: 1 time
PostPosted: Fri Jun 05, 2009 11:24 pm    Post Subject:
Alright, I'll play around with it and get some pics.
Thanks.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering All times are GMT
Page 1 of 1
Jump to:
Can You Skim Over Painted Walls? 4 420 Tue Aug 04, 2009 10:43 am
Plastering onto painted wall 3 660 Thu Jun 11, 2009 11:51 pm
plastering over a painted wall - eggshell! 5 2260 Mon Sep 10, 2007 12:38 pm
Skim plastering a painted ceiling? 6 1060 Thu Dec 02, 2004 3:03 pm
Render on painted block...can I 2 220 Tue Jun 23, 2009 8:07 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
