DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Joining Guttering
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
Author Message
Bigbray
from United Kingdom
Thanked: 2 times
PostPosted: Thu Dec 16, 2004 10:16 am Reply with quote
I'm going to replace the wood guttering on my terrace house, but I'm not sure how to join it to my neighbours guttering.
I require 18ft, which I will be buying from a local shed. This length will need halving for transport, so again how do I join these sections.
Cheers
Back to top
The following user says thank you to Bigbray for this useful post:
roofspecialistsLondon (5 Jan)
 Alert Moderators
markf
from United Kingdom
Thanked: 4 times
PostPosted: Thu Dec 16, 2004 12:36 pm Reply with quote
When you are buying the guttering you should find next to it joining pieces. There are versions to join round to round, round to square, and square to square. Each type has a small rubber band at each end that when the gutter is clipped/snapped in forms a seal.
Now joining to the old guttering of the neighbour will probably require copious amounts of silicon/mastic sealer to seal the overlap of the two gutters. However if both gutters have the same profile you may be able to use the same type of joining piece above.
Check here:-
http://www.screwfix.com/app/sfd/cat/cat.jsp?ts=00509&id=101310
Mark
Back to top
 Alert Moderators
IanDB
from United Kingdom
Thanked: 2 times
PostPosted: Thu Dec 16, 2004 2:45 pm Reply with quote
You will find that plastic guttering expands and contracts with temperature and that if you don't get a good fitting join in the first place no amount of mastic etc will keep the joint watertight. You can buy adaptors for most profiles of guttering to join one section to another. It's worth doing it properly first time around. Most guttering is pretty standard so I wouldn't have thought you'd have much of a problem (famous last words icon_biggrin.gif ).
Back to top
 Alert Moderators
TexMex
from United Kingdom
Thanked: 2 times
PostPosted: Sat Dec 18, 2004 4:06 am Reply with quote
Quote:
Most guttering is pretty standard.
Back to top
 Alert Moderators
Tom.
from United Kingdom
Thanked: 3 times
PostPosted: Wed Dec 22, 2004 2:23 am Reply with quote
My dad's house has wood guttering. Its been up for more than 100 years, and its still working perfectly icon_smile.gif
Back to top
 Alert Moderators
pipme
from United Kingdom
PostPosted: Wed Dec 22, 2004 5:04 pm Reply with quote
1) How does that work then Tom ?
2) How is it joined ?
3) Is it painted ?
4) Are the downpipes wooden too ?
P
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Wed Dec 22, 2004 5:48 pm Reply with quote
I'm guessing maybe a box section and flashing lead internal maybe ??
Back to top
 Alert Moderators
handyman2005
from United Kingdom
PostPosted: Sun Jan 02, 2005 1:56 pm Reply with quote
To join wood guttering you have to chisel out at the adjoining ends enough wood to enable a piece of lead to bedded into the gutter so it overlaps the existing guttering and the new guttering by about 4 inches. You then have to nail the lead inside the gutter but not on the flat bit at the bottom where the water will run, only on the sides, use short galvanized nails.
Then seal it with large amounts of Bitumen, make sure the gutter has the correct fall or water will well in the gutter and rot it very fast!
Apply bitumen befor and after the lead!
Good luck
_____________________________
Moderator
WEB address removed, these can be shown in your profile
Back to top
 Alert Moderators
Tom.
from United Kingdom
Thanked: 3 times
PostPosted: Sun Jan 02, 2005 3:58 pm Reply with quote
Thats pretty much it, there are no downpipes (the neighbouring property has plastic guttering and a plastic downpipe).
He went up to repair the join between the houses a few months ago, with the intention of replacing it, only to find that it was in perfect health, and why spend money for nothing?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
Joining Aquaflow guttering 12 420 Thu Jun 23, 2011 8:01 am
joining wood 2 wood guttering? 4 800 Thu Aug 03, 2006 9:09 pm
Joining aluminium to plastic guttering 2 80 Sat Jul 12, 2014 10:28 pm
Flat roof insulation at edges and joining neighbours roof 7 100 Wed Apr 10, 2013 1:14 pm
Joining new double roman to old ones - how???? 21 320 Wed Aug 22, 2012 5:34 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
