DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Combi - hot water & dirty water
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Bullbags
from United Kingdom
PostPosted: Tue Jun 09, 2009 8:41 pm Reply with quote
Could someone help answer the following 2 questions
1) Why does a drop in pressure on a combi system affect h/w operation. I recently drained system down to change some rads. Turned c/h off, left h/w on timed programme. As the c/h is a separate sealed system I didn't think this would affect h/w operation. Had to leave c/h off for a day and h/w stopped working (boiler lockout?). Anyway, altered rads, refilled system and now all ok. Just puzzled as to why h/w was affected when I thought in theory I hadn't touched this. Is it simply that h/w operation requires 1 bar reading to operate too?
2)Have been getting dirty brown water coming out of bath hot tap from combi. If bath not used for a couple of days then dirty water comes out of hot tap and lasts for about 10-15 secs then goes clear. No other taps affected. Why is this happening?
Hope my queries are clear.
Many thanks.
Back to top
 Alert Moderators
dreadnoughtheating
from United Kingdom
Thanked: 155 times
PostPosted: Tue Jun 09, 2009 8:49 pm Reply with quote
BB, the boiler does indeed require 'pressure" (pressurised water actually I suppose it should be called) to operate.
By dirty water do you mean 'milky'?, if so run it into a clean glass and see if the bubbles clear to the top of the glass. That would indicate nothing more than some dissolved oxygen bubbles trapped in water - sometimes direct from water treatment works, or again, sometimes from getting very hot in the boiler heat exchanger. So, if milky nuffink at all to be concerned about.
DH
Back to top
 Alert Moderators
Bullbags
from United Kingdom
PostPosted: Tue Jun 09, 2009 8:57 pm Reply with quote
Thanks DH. Water not milky, it's dark brown. Similar in colour to what you would get when bailing out the bottom of a header tank.
Back to top
 Alert Moderators
dreadnoughtheating
from United Kingdom
Thanked: 155 times
PostPosted: Tue Jun 09, 2009 9:05 pm Reply with quote
Hmmmm, waters mixing in a split secondary heat exchanger? - Not good, get an RGI to visit. If you are in an NR postcode area, reply and we'll make contact.
DH
Back to top
 Alert Moderators
sooey
from United Kingdom
Thanked: 185 times
PostPosted: Tue Jun 09, 2009 9:11 pm Reply with quote
You say you 'left h/w on a timed programme'. Are you sure you've got a combi? Do you have a hot water cylinder?
Back to top
 Alert Moderators
kevindgas
from United Kingdom
Thanked: 431 times
PostPosted: Tue Jun 09, 2009 10:41 pm Reply with quote
dreadnoughtheating wrote:
if you are in an NR postcode area, reply and we'll make contact.
DH
Back to top
 Alert Moderators
dreadnoughtheating
from United Kingdom
Thanked: 155 times
PostPosted: Wed Jun 10, 2009 3:46 pm Reply with quote
DH
OK, OK, so give the 'new boy on here' a break can't you? I know things are quiet business wise and yes, Devon is outside my normal work area but you can't blame a bloke for trying icon_wink.gif
So, if it is a 'Combi', is the filling loop left connected?, although the checkvalve in the loop is not supposed to let system water through, may be its a home brewed job...... just a thought
DH
Back to top
 Alert Moderators
gigz
from United Kingdom
Thanked: 84 times
PostPosted: Wed Jun 10, 2009 4:17 pm Reply with quote
If no other tap is affected i would say its the pipework to that tap i.e. iron pipe or a rusty/split flexi or even the tap itself.
Back to top
 Alert Moderators
jmln
from United Kingdom
PostPosted: Wed Apr 21, 2010 6:04 pm Reply with quote
The brown colour experienced when the tap is not used for a while is iron and is a natural element in water - it is in all ground water in different degrees, however, it is made worse when passed through metal pipes currently being changed to blue plastic as fast as the utilities can afford. Old properties also used iron pipes, again only changing them will remove some of the problem. The water companies will try and reduce it but there will always be some present. I have used a slow sand filter to remove it from a water source down to a tiny amount - it is said to be harmless but it not pleasant to drink it. It is strange how it only shows when it stands due to oxidation which turns it brown as in rust, more so when warmer. If you look inside a storage tank apart from discoloration on the tank sides there is also a furry film that attaches itself to plastic pipes because the two have different static charges which attract this is also evident in plastic pipe inside walls so that when the tap is turned on it flushes away, this is a bacterium of iron normally invisible until static. Copper pipes have a sanitising effect which prevents this occurance so beware when choosing plastic water pipes although the water companies are using it as a replacement to metal. If you choose copper for the last supply chain you should not get any of this through the tap.
Back to top
 Alert Moderators
Boilerman2
from United Kingdom
Thanked: 702 times
PostPosted: Wed Apr 21, 2010 6:08 pm Reply with quote
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Dirty water from washing machine flows up the bath plug hole 7 280 Tue Nov 09, 2010 5:09 pm
Brown Dirty Hot water 6 880 Tue Jan 27, 2004 2:37 pm
Dirty water from hot water header tank 3 820 Sun Mar 14, 2010 11:07 pm
Very dirty water when bleeding radiators. 9 380 Fri Nov 26, 2010 2:28 pm
Dirty radiator water 19 2120 Wed Oct 07, 2009 9:30 pm
DIYnot
