Hi
We are in a basement flat and have around one half of the flat the copper radiator pipes running horizontal against the wall (concrete floor so not beneath floorboards). The pipes were originally boxed in with square wooden boxing which looked awful so have taken out leaving pipes exposed for the time being.
I've installed a parquet floor and would like the pipes as hidden as possible again running horizontal around the room at floor level. so . . . I plan to remove the plaster where the pipes meet the wall creating a space for most of the pipe but not chase into the brick and then install the pipes almost touching each other at very low floor lever in this void. Skirting with a recess routed out of the back with create another centimeter or so to fit over the top. At worst I might need to block out the skirting by a centimetre or so.
I would either paint on an aluminium roof reflecting paint onto the wall and back of skirting and or use a thin foil insulation against the wall.
Can anybody see a problem with doing this?
1. how low/close to the floor can the pipes go?
2. can the feed and return pipes be touching and are there brackets available for this?
best
best
