Hotpoint Washing Machine WD420 - Flashing Error Lights
17 Jun 2009
Hampshire
Our WD420 has just suddenly started playing up and now refuses to play. Whenever we switch it on I get the RINSE HOLD (#3) and TIME SAVER (#4) lights slowly flashing whilst the ON/OFF light flashes rapidly.
When I close the door it immediately tries to fill the drum but also drains it at the same time! :confused:
From the useful info on this board and specificially rock1's post on the Hotpoint error codes (//www.diynot.com/forums/viewtopic.php?t=163622) unfortunately I still can`t find what might be up when LED's 3 and 4 are flashing.
Can anyone help?
Many thanks in advance,
Tom
Hotpoint Aquarius WD420 Washing Machine
3 and 4 mean error fo3 , pcb fault .only route to go down is call hotpoint cost you 100.00 parts and labour or if you good to change a pcb over a ex one from emw .cost about 40 quid
Sorry for the late reply rocks1 but I`ve been away.
Thanks for the rapid response - I`m a tenant and was just wanting to check if there was anything I could do before informing the landlord. While I fancy changing the PCB myself if it was mine, I guess this is why I`m paying renting.
Thanks again.
Tom
Just in case anyone has this problem in future...
Hotpoint engineer came out - PCB was fine, he replaced the thermister for good measure and refitted the heater NTC connection.
