DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Belmont rad valve leaking
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
JimDowson
from United Kingdom
PostPosted: Fri Jun 19, 2009 3:08 pm Reply with quote
Belmont type rad valve (old) leaking slightly in my bedroom, round the top, I've never had to change any of my valve before or fix them, I believe i need a new oring (s) for these type of valves.... as they're unlike the packing gland (ptfe) standard rad valves, do i need to drain down to undo/get to the o-rings?.....??
Have never worked on 1 before, so any advice would be great before I start!! They all happen at once!
Back to top
 Alert Moderators
clf-gas
from United Kingdom
Thanked: 63 times
PostPosted: Fri Jun 19, 2009 3:25 pm Reply with quote
Seeing as you want to add inhibitor to this system then why not, drain off and remove rad valve, inject inhibitor repair and replace valve, refill system and run to circulate.
Back to top
 Alert Moderators
JimDowson
from United Kingdom
PostPosted: Fri Jun 19, 2009 3:31 pm Reply with quote
Good idea!
System is full of water now though .... took ages to re-fill icon_sad.gif Was thinking of draining a bucket or so and then adding inhibitor then topping up as necessary to get back to 1.5 bar.
ARe these valves hard to replace o rings?
Back to top
 Alert Moderators
Boilerman2
from United Kingdom
Thanked: 986 times
PostPosted: Sat Jun 20, 2009 8:06 pm Reply with quote
There are two types of O ring, Red & Green, One is for the Old Belmont Valve (Grey Knob) and the other is for the newer version, I'm sorry I can't remember which is which, I do know that the valve is a nightmare to fix and only for the very brave!!
You have to turn the valve fully on, then remove the knob, undo the brass packing nut, using a spanner on the spindle, unscrew the spindle out of the valve, the spindle will leave the valve seat in place inside the body, (the pressure of water holds it in place!!!,) repalce the O ring on the spindle and NOW THE SCARY BIT... you have to re-insert the spindle into the valve and screw it back down, DO NOT PUSH OR FORCE TOO HARD or you will overcome the pressure of water holding the seat, causing it to drop which will result in a system full of water to pour out of the valve, and leaving you with a total disaster. BEST TO FIT A NEW VALVE icon_twisted.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Belmont radiator valve - source of 0 rings 2 780 Sat Sep 09, 2006 1:03 pm
Belmont Rad. Valve O-Rings 10 140 Sun Jun 24, 2012 4:49 pm
Pegler Belmont rad valves 16 1580 Wed Sep 02, 2009 3:46 pm
"O" rings for Belmont Rad Valves 26 1640 Tue May 26, 2009 12:51 pm
Belmont O-ring substitute 7 980 Tue Sep 22, 2009 3:39 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
