Quantity of gravel to fill a soakaway
18 Aug 2007
Cheshire
I have a hole 800mm deep and 1300x900 wide. How much 20mm gravel do I need to order to fill it?
A tonne bag is (nominally) 1m cube, so one of these should do the trick.
check with the supplier, they range from 0.70 up to 1 tonne.
:eek: I wasn't told to use gravel when i dug my soakaway, just broken bricks with a permeable membrane on top, then soil/turf for the top 18" or so.
Posted: Sun Jun 21, 2009 10:02 pm Post Subject:
1 cubic metre of water (1000l) weighs 1 tonne. Gravel sinks, so you will need more than 1 tonne.
most bulk bags sold are not a tonne, normally closer to .8.
weight has nothing to do with density
A little research using good auld Google reveals that 1 cubic metre of gravel 1/4 - 2 inch is 1.682 tonnes (dry) and 2.002 tonnes (wet).
