DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
sun lounge windows
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
  View previous topic :: View next topic
Author Message
climber101
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 22, 2009 9:12 pm    Post Subject:
sun lounge windows
Reply with quote Thanks
I'm planning to build sun lounge (i.e. conservatory with tiled roof), I have made a few calls looking for supply of conservatory style UPVC windows only but the places i have called aren't keen to discuss windows only and seem more keen on trying to sell whole conservatory.
Could anyone advise any company websites that describe different window options, & prices etc for this, cheers
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Richard C
from United Kingdom
Thanked: 48 times
PostPosted: Mon Jun 22, 2009 10:00 pm    Post Subject:
Are you aware that although a conservatory is exempt from Building Regulations what your proposing is effectively an extension & so must be Building Regs compliant, will require LABC inspection & many require Planning Permission. icon_wink.gif
http://www.conservatoriesonline.com/gardenrooms.htm
__________________
Richard C
Back to top
 Alert Moderators
wolfman1
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jun 23, 2009 12:19 pm    Post Subject:
Leaving aside the planning consent (i believe there is no definitive description of a conservatory, any extension is an extension, whether planning or buildings regs is required is down to the specification).
Try just buying normal upvc windows and screwing them together, we refurbished our sunlounger like this a few years ago, basicly blocked up to the window sill, and up the corners, constructed a timber frame to put the roof on add a couple of doors and you have a very cheap extension. (the biggest problem as far as planning permission goes is the size, building regs is dependent on type of construction I think a tile roof will require it to have building regs, which in turn will affect the rest of the construction.
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 48 times
PostPosted: Tue Jun 23, 2009 2:39 pm    Post Subject:
wolfman1 wrote:
i believe there is no definitive description of a conservatory, any extension is an extension, whether planning or buildings regs is required is down to the specification.
Lifted directly from the Planning Portal – Building Regulations;
Conservatories
Conservatories are normally exempt from building regulations when:
1. They are built at ground level and are less than 30 square metres in floor area
2. At least half of the new wall and three quarters of the roof is either glazed or translucent material
3. The conservatory is separated from the house by external quality door(s).
4. Glazing and any fixed electrical installations comply with the applicable building regulations requirements (see below).
You are advised not to construct conservatories where they will restrict ladder access to windows serving rooms in roof or loft conversions, particularly if any of the windows are intended to help escape or rescue if there is a fire.
Any new structural opening between the conservatory and the existing house will require building regulations approval, even if the conservatory itself is an exempt structure.
Further Information
The following common work section gives an indication of another element normally required to satisfy the requirements of the Regulations for conservatories:
• Doors and windows
• Electrics
That looks like a pretty definitive description of a conservatory to me; icon_lol.gif icon_wink.gif
Failure to meet any of the above will turn your cons. into an extension & will be required to meet ALL aspects of the relevant BR’s. Porches can also be exempt & they have a separate (but in some cases similar) definition.
Since last year there is more to it than that. Once again, lifted directly from the Planning Portal;
Conservatories
Planning Permission
Under new regulations that came into effect from 1 October 2008 adding a conservatory to your house is considered to be permitted development, not needing an application for planning permission, subject to the following limits and conditions:
• No more than half the area of land around the "original house"* would be covered by additions or other buildings.
• No extension forward of the principal elevation or side elevation fronting a highway.
• No extension to be higher than the highest part of the roof.
• Maximum depth of a single-storey rear extension of three metres for an attached house and four metres for a detached house.
• Maximum height of a single-storey rear extension of four metres.
• Maximum depth of a rear extension of more than one storey of three metres including ground floor.
• Maximum eaves height of an extension within two metres of the boundary of three metres.
• Maximum eaves and ridge height of extension no higher than existing house.
• Side extensions to be single storey with maximum height of four metres and width no more than half that of the original house.
• Roof pitch of extensions higher than one storey to match existing house.
• No verandas, balconies or raised platforms.
• On designated land* no permitted development for rear extensions of more than one storey; no cladding of the exterior; no side extensions.
Where work is proposed to a listed building, listed building consent may be required.
* The term "original house" means the house as it was first built or as it stood on 1 July 1948 (if it was built before that date). Although you may not have built an extension to the house, a previous owner may have done so.
Which in all probability means it doesn't comply with BR's &, depending on the conditions above, may need PP!
__________________
Richard C
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 52 times
PostPosted: Tue Jun 23, 2009 8:22 pm    Post Subject:
The question I find hard to reason, is why should a conservatory with a glass or plastic roof not require building regs, but if you put strips of ply in instead of the glass/plastic then it will require building regs approval?
It really is a nonsense
If the separation door remains, then what difference does the roof material make?
Back to top
 Alert Moderators
climber101
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jun 23, 2009 8:41 pm    Post Subject:
thanks for comments everyone, yes i need planning, building control approval and structural calcs. I am coming off a dining room and cutting down the existing window to form opening into it as opposed to coming off a fixed set of doors.
I have found a few companies that definitely supply the windows so looks like a face to face chat. Doubtless it will be my poor internet searching skills but here is me thinking i'd be able to find lots of sites you can plug in a few window dimensions and they'll give you some pricing to give me an idea of options/prices..
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 48 times
PostPosted: Tue Jun 23, 2009 9:44 pm    Post Subject:
Have you looked at these;
http://www.u-fit.co.uk/windows/default.asp
I have no idea of the quality though.
__________________
Richard C
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 48 times
PostPosted: Tue Jun 23, 2009 9:49 pm    Post Subject:
Ours is not to reason why. Ours is but to do or die.
Didn’t your mum ever teach you that with a clip around the ear Woody. icon_lol.gif
__________________
Richard C
Back to top
 Alert Moderators
wolfman1
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 24, 2009 4:50 am    Post Subject:
Richard C, have you swallowed a portal, well if you had you would realise that the exemption for planning permision for an extension is exactly the same as a one for a conservatory, there is no distinction between a conservatory or an extension, they are one in the same, if they meet a certain criteria they are a permitted development, it just so happens that if you build an extension that meets the criteria for exemption, it becomes what we traditionaly call a conservatory. I think it is fantastic that the new rules allow much more freedom, and also use terminology that we understand and relate to.
As for size being the main factor, then yes i believe if you build an extension that is what we traditionaly know as a conservatory, then size becomes the main factor in deciding whether it requires planning permission or not.
Back to top
 Alert Moderators
wolfman1
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 24, 2009 4:54 am    Post Subject:
Planning Permission
Planning Permission
Under new regulations that came into effect on 1 October 2008 an extension or addition to your home is considered to be permitted development, not requiring an application for planning permission, subject to the following limits and conditions:
Two-storey extensions no closer than seven metres to rear boundary.
Materials to be similar in appearance to the existing house.
Upper-floor, side-facing windows to be obscure-glazed; any opening to be 1.7m above the floor.
On designated land* no permitted development for rear extensions of more than one storey.
On designated land no cladding of the exterior.
On designated land no side extensions.
This is lifted directly from planning portal
I think that buildings regs is required, if certain other requirements are not met ie roof, heating, doors between house and conservatory.
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 48 times
PostPosted: Wed Jun 24, 2009 7:41 am    Post Subject:
Are you trying to make some sarcastic point or other icon_question.gif I just happen to use certain BR’s a lot & it was much easier to lift the definitions from the horse’s mouth as it were, what’s your problem with that; or do you think I am just talking “rubbish” again. icon_confused.gif
In so far as permitted development goes then I didn’t say it wasn’t & I don’t really disagree with the rest of your play on words. The need to apply for planning permission or otherwise is dependant upon a number of factors, you advised the OP that it's mainly to do with size which it isn’t.
__________________
Richard C
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 48 times
PostPosted: Wed Jun 24, 2009 7:42 am    Post Subject:
wolfman1 wrote:
Planning Permission
Planning Permission
__________________
Richard C
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Removing and replacing lounge window same day for couches 5 400 Thu Mar 29, 2007 4:27 pm
Who Made These Windows - Where Can I Get New Rubber Gasket? 2 400 Sat May 31, 2008 4:30 pm
Correct way to use sealant around windows 6 360 Sun May 25, 2008 7:19 pm
UPVC Stained glass windows? 7 460 Sun Jun 01, 2008 3:41 pm
Can you use household filler to fill in windows instead..... 4 280 Mon Jun 23, 2008 3:52 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
