DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Bringing twin electric socket flush
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry
  View previous topic :: View next topic
Author Message
den9112
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jun 26, 2009 8:26 pm    Post Subject:
Reply with quote Thanks
Hi i have put some 7.5mm TandG with 5mm batons on my dininig room wall , i have a twin electic socket that as a metal box fitted in the wall . I have cut the TandG to fit,however the socket is now set back inside the TandG i would like to bring it forward so it is sitting flush , not sure how to do this . i know if i bring the metal box forward 10 mm or so it will be flush with the panels , just cannot get my head round it at the moment on the best way to do this ,could anyone please help. Thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Burnerman
from United Kingdom
Thanked: 51 times
PostPosted: Fri Jun 26, 2009 8:45 pm    Post Subject:
Unfortunately, if you had cut the T&G to gang box size, outlet removed, the larger size of the outlet would have been flush with the T&G using longer 3.5mm screws when it was replaced....however, I guess you'll have to disconnect the outlet and pack it out 10mm to get it to look right. You can probably buy plastic wall plates (that fit around light switches to prevent finger marks) if that would suit....can't say I've seen double outlet sizes though. Cheers John
Back to top
 Alert Moderators
den9112
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jun 26, 2009 8:55 pm    Post Subject:
Thanks for the reply, i have had a break and a second look . If i can make a block spacer the same size as the metal box that is recessed in the wall, drill holes to accomadate the two screws bring it forward and purchase two screws 10mm longer than the origanal ones that will bring it flush to my panels . I hope .
Back to top
 Alert Moderators
den9112
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jun 26, 2009 9:11 pm    Post Subject:
Just found these, M3.5 3.5MM SOCKET SWITCH SCREW EXTENSION STUDS BAG OF 4 should do the job.
Back to top
 Alert Moderators
dextrous
from United Kingdom
Thanked: 49 times
PostPosted: Fri Jun 26, 2009 11:24 pm    Post Subject:
Or you could use a drylining pattress and get rid of the metal box anyway icon_wink.gif
__________________
A rolling stone gathers no moss.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry All times are GMT
Page 1 of 1
Jump to:
Metal socket / bracket for table legs 3 560 Wed Feb 25, 2009 12:36 am
Skirting around radiator and socket 4 1220 Mon Jan 19, 2004 10:16 pm
kitchen worktop noty flush with wall 2 380 Thu Jul 05, 2007 4:33 pm
Flush Fitting Wall Mounted Handrails 3 420 Sun Jan 27, 2008 9:08 pm
flush door 4 200 Sun Jan 04, 2009 10:12 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
