Hotpoint WD440g - Error F03?
27 Jun 2009
Bristol
Help!
Having taken my washing machine to bits and cleaned and reassembled on advice from other sites I'm still getting the same error code - I think it's F03 (rinse hold - 3rd from top, time save - 4th from top and on/off lights flashing).
Rocks1 - are you out there? Seen lots of great tips from you on other errors.
Though of course - ANY help would be fantastic! I'm broke and really can't afford the £100 Hotpoint want just to turn up!
Cheers!!
hi yes you have f03 ntc prob . it can be two things the ntc is on the heater two thin bue wires on it .Remove plug from mains and NTC sensor, use the probes to perform a resistance test. You should get a reading in kOhms. Replace plug in NTC, remove matching plug on pcb, and measure from that end - you should get a very similar reading. if not then a pcb fault ex board will cost about 45 quid from emw .
Thanks for the info!! Much appreciated. Part ordered so fingers crossed it'll work out.
Cheers!
