DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Extending individual corese
This topic originated from the How to page called Extending a flex
Click here to return to the page called Extending a flex.
  View previous topic :: View next topic
Author Message
rglister
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 20, 2004 11:11 pm    Post Subject:
Reply with quote Thanks
What is the best way to extend individual mains cores within a socket housing?
1) Crimping
2) Solder and heat shrink sheath
3) connector block
Are there any other options? Cables are plastered in and it would be painful to replace.
Regards
Rob
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Tue Dec 21, 2004 12:07 am    Post Subject:
termina block tends to be rather bulky and therefore hard to get into the enclosure
soldering is fine IF you are good at it but i wouldn't generally reccomend it
so most sparks i know use crimps but if you use theese make sure you get a decent ratchet crimper
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 0 times
PostPosted: Tue Dec 21, 2004 9:58 pm    Post Subject:
since it will be inaccessable (in the wall) you cannot use a terminal block. it must be permanent (i.e crimped, soldered)
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Tue Dec 21, 2004 10:02 pm    Post Subject:
I think he means in behind a socket front (in the back box).
Still go for the crimp option - with a ratchet crimper.
Back to top
 Alert Moderators
Emtpencil
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 18, 2006 2:11 pm    Post Subject:
Extending a ring.
If you are able to extend the ring from a socket itself, would it be ok to fit a connector block within the pattress rather than soldering or crimping ?
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
replacing track light with individual pendants 6 160 Sun Feb 01, 2009 8:06 pm
4 individual switches into 1 4 gang switch 2 340 Tue Mar 20, 2007 2:10 pm
Extending Wires 5 220 Sat Feb 16, 2008 11:32 am
Extending a mains socket cable 30 1380 Wed Feb 27, 2008 8:47 pm
extending cooker fuse box 8 320 Sat Mar 08, 2008 11:29 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
