DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Flashing into rendered side wall abutment, Help
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
Author Message
des606
from United Kingdom
PostPosted: Mon Jun 29, 2009 9:32 am Reply with quote
Hello,
I'm about halfway through slating a shed/workshop roof which abuts another shed, and I'm looking ahead to flashing.The other shed is breeze block (large blocks with holes in the middle??) and has a rendered finish.
I've read that to install lead flashing a channel of 25mm should be cut / grinded into brickwork. So with a rendered wall do I cut in 25mm plus render say 50mm in total.
What else do i need to know / take into account ??
Cheers
Back to top
 Alert Moderators
justlead1
from United Kingdom
Thanked: 8 times
PostPosted: Mon Jun 29, 2009 11:37 am Reply with quote
Hi The easiest way is to lay say a 100 mm board against abutment wall and its edge on roof, the top edge gives you a line to work to. The grove you are cutting needs to be perfectly straight to accommodate the lead flashing. The depth of chase needs to be say 35 mm from the face of the render, this will provide sufficient depth for the 30 mm turn on the sheet lead flashing. You may need make the chase wider at any point where the lead is lapped. Good Luck
Back to top
 Alert Moderators
des606
from United Kingdom
PostPosted: Mon Jun 29, 2009 11:17 pm Reply with quote
Cheers justlead1,
What would you recommend using to case the channel?
I've been told to use a grinder, am I right in thinking I'd have to grind two parrallel channels and chisel out the middle to make it wide enough to fit led and lead wedges?
Back to top
 Alert Moderators
dextrous
from United Kingdom
Thanked: 194 times
PostPosted: Mon Jun 29, 2009 11:52 pm Reply with quote
Don't think you need to cut a chase - just a groove. (Code 4) Lead can be held in place every 450mm with any thin wedge you can get in there, then run silicon along the top to make it waterproof. Make the strips no longer than 1.5m and overlap by 100mm
Back to top
 Alert Moderators
gaz116
from United Kingdom
PostPosted: Thu Jul 02, 2009 12:44 pm Reply with quote
Also, you can pick up 4" diamond blades which are about 8mm thick which are perfect for grinding out for lead Gives plenty of space for the lead and bullets. Not particuarly expensive either
Back to top
 Alert Moderators
roy c
from United Kingdom
Thanked: 312 times
PostPosted: Sat Jul 04, 2009 3:10 pm Reply with quote
I wouldn't use silicon on lead-work. Use something like leadmate or similar.Silicon reacts with the lead....
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
Replacing abutment flashing on rendered wall 4 820 Mon Apr 23, 2007 2:40 pm
Rendered over Lead Flashing. 9 360 Tue Jun 11, 2013 5:55 pm
side abutment how to?? 12 1140 Fri Mar 09, 2007 12:25 pm
Ridge beam abutment to existing wall 18 8000 Mon Aug 07, 2006 5:38 pm
Leak on abutment roof to pebbledash wall 11 960 Tue Dec 29, 2009 10:21 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
