benmaye
Joined: 16 Apr 2009 Posts: 49 Location: Surrey, United Kingdom Thanked: 0 times
Posted: Wed Jul 01, 2009 7:22 am Post Subject: Drain Cock Type A Heavy Pattern & Type B |
Hi all,
just about to buy some Drain Cocks when I noticed they are sold as either type A Heavy Pattern and type B Light. whats the difference and where would you use them individually. Mine are to be used just for 15mm pipe on a shower. For the sake of the 25p difference in price between them it doesn't really matter, but just curious
cheers |
gas4you
Joined: 23 Feb 2007 Posts: 14312 Location: Norwich, United Kingdom Thanked: 41 times
Posted: Wed Jul 01, 2009 7:39 am Post Subject: |
Type A are supposed to be leak proof when they are open and used for draining. They have an extra 'o' ring in them to acheive this. __________________ Dave
DRL Gas Services |
TicklyT
Joined: 30 Jul 2006 Posts: 1873 Location: Hampshire, United Kingdom Thanked: 20 times
Posted: Wed Jul 01, 2009 7:48 am Post Subject: |
There is no seal around the spindle of a type 'B'. When you open it most of the water runs up your sleeve or comes out sideways around the threads instead of out through the outlet. It's little different to loosening a blank end cap on a stub end of pipe.
The heavy pattern has a seal around the spindle which should keep most of the water flowing through the outlet. __________________ If it isn't broken, keep fixing it until it is |
benmaye
Posted: Wed Jul 01, 2009 7:50 am Post Subject: |
cheers guys, much appreciated
Ben |
OilLecky
Joined: 16 Sep 2008 Posts: 157 Location: Gloucestershire, United Kingdom Thanked: 0 times
Posted: Wed Jul 01, 2009 10:16 am Post Subject: |
Thanks from me too!
I thought that I was the only person in the world who attached a hose-pipe to a drain cock and then had all the water go up my sleeve and over the floor instead of through the hose! In fact it's due to someone saving 25p during the initial fit!!  |
gas4you
Posted: Wed Jul 01, 2009 6:43 pm Post Subject: |
Watch out for some cheap type A drains at Plumb Center. They have the second seal omitted around the outer holding top.
Eagle ones are the same price, but have this extra 'o' ring. __________________ Dave
DRL Gas Services |
namsag
Joined: 12 May 2004 Posts: 7929 Location: United Kingdom Thanked: 59 times
Posted: Wed Jul 01, 2009 9:36 pm Post Subject: |
Cannot understand why anyone buys type B complete waste of money |
