Security lights - advice on cable run please
21 Dec 2004
Hi
I'm about to install a couple of outdoor security lights. For one of them I'm able to access the back of the lamp going straight through the exterior wall.
The other requires a cable run vertically down the outside of the house, with the run originating in the loft. I can't find any info that specifies whether I need any sort of cable protection in this scenario.
Obviously the cable itself is weatherproof, and it's not going to be subject to external impact or abrasion .... but it still seems "wrong" to be running bare cable outdoors! Anyone shed more light on this please (no pun intended)?
most people just use PVC flex, but to be honest am not sure what is susposed to be used. if you wanted to go to extremes you could use SWA
Yeah ... it's the "supposed to be used" bit I'm concerned about :)
Twin and earth cable may be used outdoors out of direct sunlight due to the effects of solar gain. It can also become brittle with climate temperature change.
Can you not drill at an angle to get the cable to enter the rear of the light?
twin + earth and pvc flex are NOT designed to be used permanently outside. You could put the cable in plastic conduit or use "arctic blue" flex which IS designed to be used outside
Okay. I must admit I was considering plastic conduit, but more out of guesswork than knowledge .... hence the question. That's helpful - thanks folks.
Didn't I read in the Nic Technical Manual that they frown upon drilling through exterior walls because of water ingress. It makes sense, but Have often wondered how the hell else they expect you to get a cable through. Or am I missing the point somewhat? :confused:
if drilling from inside out drill downwards at a slight angle
and use silicone as extra protection
no problems with the drilling down or use of silicon, but if they are gonna get picky, where do i get silicon that don't contain plasticiser?
