DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Moving my BT box - photos
Post new topic   Reply to topic    DIYnot.com Forum Index > Alarms, CCTV & Telephones
  View previous topic :: View next topic
Author Message
Prestonian
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 02, 2009 9:05 pm    Post Subject:
Reply with quote Thanks
Hello,
We need our BT box moving, from where it enters the house above our front door...
Login to view this image
...to our front room downstairs. The second pic shows where the cable runs into the house now, and where we'd like it to go (continuing straight down). I know I shouldn't really move it myself, but it seems an expensive call-out for a simple job, especially when the existing cable won't need extending.
My question is, are there any problems with the proposed route crossing our mains electricity supply outside (in terms of line interference)? I ask, cos the existing route seems to take a route to avoid it.
Thanks in anticipation.
Edit: err, might just have found the answer to that... I need to leave 50mm between phone cables and electric cables?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
djrock
from United Kingdom
Thanked: 7 times
PostPosted: Fri Jul 03, 2009 1:43 pm    Post Subject:
You can cross a mains cable but when it’s running parallel with it you can get problems if it’s too close.
If it was me, I would not touch it! That belongs to bt. At a guess I don't think a bt engineer would cross the incoming mains supply.
Back to top
 Alert Moderators
Prestonian
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 03, 2009 9:39 pm    Post Subject:
Ok, thanks. i'll get a man in.
Back to top
 Alert Moderators
simonpolly
from United Kingdom
Thanked: 1 time
PostPosted: Sat Jul 04, 2009 11:06 am    Post Subject:
Move it
i`d move it, you`d be o.k,make sure you put a drip loop at the bottom and seal the hole where it enters the house,as long as you leave the dropwire clamp alone at the top of the house b.t will never know,or care.As for crossing the electric cable its only 240v and insulated and unlikely to cause any problems to your bb.From one that knows,when a internal line is run around a industrial unit or office/shop etc its impossible not to cross a electrical cable.( I SEE YOU HAVE OR HAVE HAD TWO LINES INTO THE HOUSE O/W LINE 1 G/B LINE 2)
Back to top
 Alert Moderators
Prestonian
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 06, 2009 8:45 am    Post Subject:
Thanks. Yes, two lines - one home phone and one for business phone/broadband.
Back to top
 Alert Moderators
Sureitsoff?
from United Kingdom
Thanked: 1 time
PostPosted: Mon Jul 06, 2009 7:19 pm    Post Subject:
rather than move the existing box, wouldit not be easier to take two extensions from the main box to where you need them.
you could go in different directions with the extension wiring if needs be
Back to top
 Alert Moderators
Prestonian
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 07, 2009 8:08 am    Post Subject:
You're dead right, that would be much easier, but the master box looks a bit of an a**e stuck there over the door (the previous owner had some kind of 'exchange' up there), so we'd like to move the box - and a single socket that powered the exchange - whilst the house is in turmoil (a renovation).
Back to top
 Alert Moderators
dannyboi2003
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 07, 2009 3:23 pm    Post Subject:
Is any of the telephone cabline or sockets left from the "exhange" or has it all been removed?
Back to top
 Alert Moderators
Sureitsoff?
from United Kingdom
Thanked: 1 time
PostPosted: Tue Jul 07, 2009 4:32 pm    Post Subject:
if you are renovating the house i would move the cable as suggested and fit two new style sockets where the cable enters the house and from them i would take extensions to every room.
fitting new style sockets makes the extension wiring easier and the broadband ext socket if req can be filtered at the first socket with one of these
http://www.google.co.uk/url?q=http://www.adslnation.com/phpapps/catalog/product_info.php%3Fproducts_id%3D105&ei=MnhTSvHfJsKZjAf2uv2cCQ&sa=X&oi=smap&resnum=1&ct=result&cd=1&usg=AFQjCNG98aeIsy6t3AewJ8cYMZM0Tb9yEA
to enable you to do away with the microfilters(if you have them )
i have one of these adsl faceplates and can recommend it
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Alarms, CCTV & Telephones All times are GMT
Page 1 of 1
Jump to:
Satalite cable to booster amplifier see the photos please 2 260 Tue Dec 23, 2008 2:11 pm
Moving PIR's? 3 240 Wed May 20, 2009 1:42 pm
moving bt wire 5 400 Wed Jun 17, 2009 10:16 pm
Moving House 14 480 Sat Aug 15, 2009 11:37 am
MOVING BT CONNECTOR BOX 10 600 Tue Nov 25, 2008 4:45 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
