DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
moving kitchen to another room
Post new topic   Reply to topic    DIYnot.com Forum Index > Building Regulations and Planning Permission
  View previous topic :: View next topic
Author Message
juemckool
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 03, 2009 4:44 pm    Post Subject:
Reply with quote Thanks
i have a terraced house where the gallery kitchen is located in a extension to rear of property. can i move this kitchen to the existing lounge, which is at the rear of the property. (its a 2 up 2 down layout~) the stairs are located in this room to - with a door.i wish to locate the cooker on a internal wall ie not extracted to an outside wall. would this need consent too?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
inspector01
from United Kingdom
Thanked: 1 time
PostPosted: Fri Jul 03, 2009 5:16 pm    Post Subject:
You will need to obtain Building Regulation approval and also consider the following points:
1) All electrical alterations and new circuits would need to be part P or if done by yourself inspected by Building Control and tested by a qualified Electrician.
2) Drainage
3) Extract ventilation
and most importantly means of escape. If you currently have an open plan layout, you would need escape windows in the bedrooms and heat/smoke detection. Building regs fee would be based on the cost of a contractor carrying the work out (even if DIY), as a rough guess base the application on £5000
Back to top
 Alert Moderators
juemckool
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 03, 2009 5:23 pm    Post Subject:
1) qualified electrian will beused and issue a cert
2) drainage is only 3 feet from exisiting into sewer
3) ventilation./extraction is my main worry - as the hob would be on an internal wall, so couldnt extract externally. can i use a recirculator hood? do i have to have extraction of kitchen fumes and condensation?
i asked them if i needed to have consent re. fire door and means of escape. it isnt open plan just small 2 up 2 down, the only thing being changed is location of kitchen to adjoing room
Back to top
 Alert Moderators
inspector01
from United Kingdom
Thanked: 1 time
PostPosted: Fri Jul 03, 2009 5:35 pm    Post Subject:
If the new kitchen is seperated from the stairwell by a door then you are OK. Extract can be located on an external wall but must achieve 60L/s, in real money this usually means a 9" fan but there are 4" fans on the market that achieve this.
Unfortunately Building Regs will still be required due to the ventilation requirements... icon_sad.gif
Back to top
 Alert Moderators
juemckool
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 03, 2009 6:10 pm    Post Subject:
Back to top
 Alert Moderators
juemckool
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 03, 2009 6:32 pm    Post Subject:
i have an idea icon_smile.gif - if a hood isnt possible - what about any form of extraction i.e fan on external wall..which would be located approx 10 feet from cooking area.
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Fri Jul 03, 2009 7:38 pm    Post Subject:
duct it through the floor void to an outside wall.. it's not rocket science..
__________________
If you make everything idiot proof, evolution will just make a better idiot.
Back to top
 Alert Moderators
juemckool
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 03, 2009 8:16 pm    Post Subject:
might not be rocket science but it is a solid concrete floor
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Building Regulations and Planning Permission All times are GMT
Page 1 of 1
Jump to:
'moving' a bedroom 4 460 Thu Jun 18, 2009 2:11 pm
fitting a new bathroom in my attic room 5 440 Sat Jul 25, 2009 8:47 am
loft room 5 460 Sat Sep 05, 2009 10:30 am
NOT a loft room 7 480 Thu Sep 17, 2009 3:30 pm
Building control for new shower room 2 360 Wed Oct 07, 2009 11:20 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
